It is currently Tue Jul 22, 2025 7:34 pm
 Post subject: blueish whiteish smoke
PostPosted: Sat May 29, 2010 4:38 pm
what does it mean engine has been sitting for 6 months but i swear it wasn't so Smokey before
PostPosted: Sat May 29, 2010 4:55 pm
constant smoke? have you let it run and then wait for it to cool then try again? does it smoke up again?
does it smell of oil?
1978 Leyland Clubman S
PostPosted: Sat May 29, 2010 5:06 pm
yes constant smoke a lot more when you put your foot down
PostPosted: Sat May 29, 2010 5:14 pm
This space for rent
Rings
Have you checked the dipstick for water/coolant?
PostPosted: Sat May 29, 2010 5:16 pm
I think: blue means oil
white means petrol(too much)
Im not sure why your motor is making funny colurs now though wait for some of the mechanical problem solvers get on 8)
PostPosted: Sat May 29, 2010 5:44 pm
seals/rings
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Sat May 29, 2010 5:53 pm
Do you have a brake booster on the car
PostPosted: Sat May 29, 2010 5:54 pm
just been and started her again and smoke did not seem so bad ,mind you it is pretty much dark here now but it got me to thinking that when i bled my clutch the fluid sprayed all over the extractors possably some of it ran into the exaust through my slip joint well hopefully that is it but i womt know until tomorow for sure ,,,how will i sleep now
PostPosted: Sat May 29, 2010 5:55 pm
whjat do we need those for the car does not weigh enough :D
PostPosted: Sat May 29, 2010 6:30 pm
It is more than likely just some oil that has run down on to the top of the piston crown. I would not panic just yet! :wink:
PostPosted: Sat May 29, 2010 6:48 pm
sometimes when motors are left for a good while they just need a good long run to clear everything out of it i would try this before i do anything drastic
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
PostPosted: Sat May 29, 2010 6:51 pm
Agreed. Just drive it.
PostPosted: Sat May 29, 2010 8:59 pm
Also possible the valve stem seals have gone hard and doing nada.
Smoke from excess fuel will be black, white/blue smoke is oil. Hopefully it will clear, but if you have some stuck rings things may not be so flash. See how it goes after a proper run with some load on the engine.
Jacob
PostPosted: Sat May 29, 2010 10:04 pm
Tomboss Breweros
From what you have said Jimmy it sounds like the whole mini is burning oil and you should just give it to me :wink:
No mini = no smoke :lol:
kimini wrote:
Jimmyinamini wrote:
Users browsing this forum: Gatti and 89 guests
