It is currently Fri Aug 22, 2025 6:19 pm
Post new topic Reply to topic  [ 88 posts ]  Go to page 1, 2, 3, 4, 5, 6  Next
 Post subject: Engine Rebuild Time
PostPosted: Tue Jun 01, 2010 6:21 pm
G'day fellow mini lovers,
The time has come to rebuild the engine in my beloved little car, so I thought I would check with you for a list of the bits and pieces that I'm going to need.
I reckon I need the following - feel free to add to the list as there's bound to be stuff that I'll forget.
*Gaskets
*Gasket cement, Locktite etc
*New locking/spider washers for the cam end plate
*New pistons - not yet sure of what oversize
*teflon plugs to ensure the gudgeon pin cir-clips stay in place - if they're still available
*New welch plugs
*New oil pump
*New cam followers - maybe. Depends on their condition and if a cam re-grind is needed
I'll be using a different 1100 block to the one currently in the car, as a gudgeon pin cir-clip disintegrated a year or so ago and one bore is horribly scored. Planning on using the existing head with just a clean up of the valves etc The gear-box is fine and the clutch too but will check these when it's all apart.
Sounds easy doesn't it
Hooroo
Rod Image
PostPosted: Tue Jun 01, 2010 6:22 pm
Don't forget GR 100 thou pistons ;-)
Mini, its in my blood........
PostPosted: Tue Jun 01, 2010 6:23 pm
Wow....that was a quick reply!
Yep, GR's stuff is good.
Rod Image
PostPosted: Tue Jun 01, 2010 8:05 pm
Crank & Rod Bearings & I would say Timming Chain and Oil Pump
PostPosted: Tue Jun 01, 2010 10:01 pm
It all should be a good engine other than the stuffed bore?
Get a nice cam grind while ya at it. ;)
PostPosted: Wed Jun 02, 2010 7:09 am
My sentiments exactly. Go on Rod you know you want to.........
BTW the teflon buttons actually replace those dreaded circlips.
Rod.
______________________________
'63 Morris 850 (Old Secondhand CAR)
PostPosted: Wed Jun 02, 2010 7:47 am
Karcraft have engine 'kits'. They have most parts that you'll need for a engine reco / rebuild, they use all top quality parts (most as per OEM) and they are extremely good value for money :wink:
New timing chain does mean new gears so keep that in mind too.....be sure to use a duplex set up.
I wouldn't recommend using Teflon buttons for the gudeon pins, they are OK, but can have poor life, especially in an 1100 since it has a long (very long) stroke. Circlips are only asking for trouble. Use Aluminium buttons :wink:
PostPosted: Wed Jun 02, 2010 4:58 pm
I'm already using a duplex timing chain - see what condition it's in after about one and a half years of use, but while it's all apart I might just replace it with a new one. Anybody know the life cycle of a duplex chain under normal conditions???
Not so sure about a different cam......yep, it would be nice but I have no plans on upgrading the drum brakes or the 'cheese cutter' wheels/tyres. I'm not planning to go any faster so.........
Teflon buttons....aluminum buttons.....I've never used them before but I only know of the teflon ones that are in Rod's mini, so lets have some discussion on the pros and cons of both.
New crank and con-rod bearings - again, it depends on the condition of the existing ones seeing as this rebuild isn't too old. Again, see how the old ones are but I really do expect to do this as a matter of course.....They will be replaced if I get a crank re-grind.
As of right now, I have no idea of the state of the cam bearings in this other block......again, when I start, I'll have to have a look.
Rod Image
PostPosted: Wed Jun 02, 2010 5:33 pm
I last built a 1220 Sprite motor with Imp pistons & teflon buttons on 13/9/2003.
It's still going fine and apparently so are the buttons (head was off recently for a look).
If using circlips, put em in the right way round... sharp edges OUTWARDS.
:wink:
PostPosted: Wed Jun 02, 2010 9:27 pm
300,000km on std pistons and circlips - cant be too much wrong with them.
That said I have done the teflon buttons in the rebuilt engine too.
Lots of gasket goo will stop theleaks too :D
Rob Forsyth
Miniot!!
PostPosted: Thu Jun 03, 2010 11:00 am
dont forget the acid bath first, it relaxes the mind body and soul
massage the bores and deck,
lubricate the bearings and cam
drink plenty of liquid gold
take a big breath and relese
PostPosted: Mon Jul 05, 2010 4:55 pm
Ok, the engine is about to be lifted out - well, tomorrow or Wednesday. While I was preparing everything, moving stuff out of the way etc. I've lost one of the ball bearings out of one pot joint/drive shaft - buggered if I can find it.
Is there some kind soul with a spare that I could buy it from you???
Thanks :oops:
Rod Image
PostPosted: Tue Jul 06, 2010 7:55 am
Thanks :oops:
get a new one from a bearing shop. search for the size in other threads .....
PostPosted: Tue Jul 06, 2010 8:19 am
Thanks :oops:
A good place to get them but take a 'sample' one from the same joint. If it is not original or been recoed, then it may not have an original sized bearing in it :wink:
PostPosted: Tue Jul 06, 2010 11:27 am
Just checking out the engine numbers on the two blocks I have - one will be the lucky one !!!
10YF/U/H9024 looks in much better condition than.........
1015/8111 followed by a stamp of a map of Australia
This second one is odd - can any-one throw any light on it please.
Rod Image
Users browsing this forum: No registered users and 252 guests
