It is currently Thu Aug 14, 2025 1:00 am
PostPosted: Fri Jun 04, 2010 2:02 pm
OK I want to buy some monograde 140EP gear oil in 4L bottle, for filling Mini racks.
All the usual suspects (Repco, Supercheap etc) only seem to carry 85/90EP and sometimes 90/140EP multigrade and they want ~$40 for it.
Monograde is thicker under ambient conditions (in a rack), lubes the teeth better and is less likely to give leaks.
Anyone seen any for sale lately?
PostPosted: Fri Jun 04, 2010 2:20 pm
Gave Caltex Lubelink a ring.
He suggested BP, as they do one in straight 140W. Where you would get it I don't know, but possibly a BP servo if you don't know of any distributors ?
Caltex have one, but it is 85W-140
**EDIT** -After looking up the details, BP Gear Oil 140 EP is no longer manufactured.
PostPosted: Fri Jun 04, 2010 2:22 pm
find the distributor.... I bought my 130 grade oil from Repco, but it's a little shop that mostly does trade
PostPosted: Fri Jun 04, 2010 2:36 pm
Mods rock!
Try Shell Omala 150. Blackwoods, Bakers or most Industrial Suppliers. Superior to most EP140's :wink:
PostPosted: Fri Jun 04, 2010 2:44 pm
If he went that, he may aswell go with the multigrade EP gear oil, as its going to have the same viscosity as an 85W EP gear oil.
Our equivilant is the Meropa 150, with a viscosity index of 101, the Thuban GL5 EP 85W140 is at an index of 97.
PostPosted: Fri Jun 04, 2010 3:04 pm
Fill it with Grease.
PostPosted: Fri Jun 04, 2010 3:12 pm
All Minis here had their original racks filled with oil.
Around half the Mini racks I've pulled apart that had had grease put in em, it had all gone hard. Rusty pinion bearings, scored rack & pad, etc. Useless...
OTOH ones that had some oil in were all pretty good.
Penrite still do a 140EP, but dunno who would stock it.
[edit] Repco are Penrite agents....
http://www.penriteoil.com.au/products/g ... hypoid_140
viscosity index is 96. So maybe it ain't that thick.. what temp is this taken at Maxi, any idea?
PostPosted: Fri Jun 04, 2010 3:47 pm
seems it only comes in 20L drums so that would be enough to last you a month of Sundays :P
PostPosted: Fri Jun 04, 2010 3:59 pm
lucas do a 85/140 gearoil in small bottles 946ml
i used penrite 90/140 in my 9"diff bought in 2 ltr bottle from thompsons spare parts qld
PostPosted: Fri Jun 04, 2010 4:02 pm
Um.. @ 200mL ea, that's only about 100 racks... :shock:
PostPosted: Fri Jun 04, 2010 4:07 pm
try ur local diff rebuilder
PostPosted: Fri Jun 04, 2010 4:13 pm
Just thinking Doc, would not EP90 with a molydisulphied additive be good enough to do the trick? EP140 would be like treacle in the cold?
PostPosted: Fri Jun 04, 2010 4:21 pm
I can get Shell Omala oil through work, (Blackwoods account) we need a 20L drum for some machinery anyway.
Which viscosity would compare to a 140EP monograde diff oil (at ambient temp)? There are a whole range of em here...
http://www2.blackwoods.com.au/infoBANKP ... &P=2026195
PostPosted: Fri Jun 04, 2010 5:30 pm
Mods rock!
This one
http://www2.blackwoods.com.au/PartDetai ... o=04426101
I'll go you halves if you like.
PostPosted: Fri Jun 04, 2010 9:04 pm
I'm going to have to be frugal with the oil I've got then... it's Castrol and says "STH 140 Straight Mineral Gear Oil" on the label.
Can't find it on the castrol website, tempted to go back to Repco and see if they still have it on the shelf
Users browsing this forum: No registered users and 295 guests
