It is currently Thu Jul 24, 2025 1:24 am
 Post subject: Nuts & Bolts
PostPosted: Tue Jun 08, 2010 1:51 pm
G'Day guys,
Just after some reconmendations on the cheapest and easiest way to obtain an amount of nuts and bolts to use on the mini. I'm pretty sure I seen a kit on a foreign website, but now I cant locate it. Would prefer a kit, as oposed to making an order at a nut/bolt shop for so many of this and so many of that.
Nathan
PostPosted: Tue Jun 08, 2010 1:54 pm
Rover Cooper
What type, make ( Rover etc.) and mAke of car are we talking about. :wink: :wink:
PostPosted: Tue Jun 08, 2010 2:01 pm
1965 Morris mini
UNF i believe.
PostPosted: Tue Jun 08, 2010 2:03 pm
Rover Cooper
That will make it easier, now you should get some replies to your request.
Cheers mate....... :wink: :wink: :wink:
PostPosted: Tue Jun 08, 2010 5:08 pm
Mods rock!
Make your own list, it won't take too long and you'll actually get to 'learn' your car even more. If you go to a decent fastener supplier with your list and asked for a quote most of them - in box quantities - I think you would be pleasantly surprised :wink:
Should be about 10 to 15% of 'Kit' sets and you'll have all of them instead of most.
Most of the factory fitted fasteners are zinc plated and grade 5 tensile.
PostPosted: Tue Jun 08, 2010 5:52 pm
Harley had a list some time back of all the nuts and bolts for a mini, throw him a PM and see if it still exists.
PostPosted: Tue Jun 08, 2010 6:09 pm
List of Engine Bolts
Timing Cover
• 5 x Bolts Cap Head 5/16”UNF (3/4” Long)
• 6 x Bolts Cap Head 1/4”UNF (7/16” Long)
• 5 x Washers 5/16”PLN (5/8” OD)
• 5 x Washers 5/16”SPR (1/2” OD)
• 6 x Washers 1/4”PLN (9/16” OD)
• 6 x Washers 1/4”SPR (7/16” OD)
• 1 x Nut 5/16”UNF (1/2” Head)
• 1 x Nut 1/4”UNF (7/16” Head)
Coolant Circuit
• 2 x Bolts Heater Tap 1/4” UNF (7/16” Head, 1/2” Long)
• 2 x Washers Heater Tap 1/4” SPR (3/8” OD)
• 2 x Bolts Radiator Top 1/4” UNF (7/16” Head, 1 1/2” Long)
• 2 x Washers Radiator Top 1/4”PLN (9/16” OD)
• 2 x Bolts (Water Pump) 5/16”UNF (1/2” Head, 2” Long)
• 2 x Bolts (Water Pump) 5/16”UNF (1/2” Head, 1” Long)
• 4 x Washers (Water Pump) 5/16”PLN (5/8” OD)
• 4 x Washers (Water Pump) 5/16”SPR (1/2” OD)
Thermostat (Short)
• 3 x Bolts 5/16 UNC (1/2” Head, 1 1/2” Long)
• 3 x Washers 5/16” SPR (1/2” OD)
Engine Electrical
• 2 x Bolts (Alt’ top) 5/16”UNF (1/2” Head, 2” Long)
• 1 x Bolt (Alt’ Bottom) M8x20
• 1 x Nut (Alt’ Bottom) M8 NyLoc
• 4 x Washers (Alternator) 5/16”PLN (5/8” OD)
• 4 x Washers (Alternator) 5/16”SPR (1/2” OD)
• 2 x Nuts (Alternator) 5/16”UNF (1/2” Head)
• 2 x Bolts Starter Motor 3/8”UNC (9/16” Head, 1 1/4” Long)
• 2 x Washers Starter motor 3/8”SPR (5/16” OD)
• 1 x Bolt (A+ Distributor) 5/16” UNF (1/2” Head, 3/4” Long)
Clutch Slave (Non verto)
• 2 x Bolts (Cyl Mount) 3/8”UNC (9/16” Head, 1” Long)
• 2 x Washers (Cyl Mount) 3/8”SPR (5/8” OD)
• 1 x Bolt (Arm Stop) 1/4”UNF (7/16” Head, 1” Long)
• 1 x Lock Nut (Arm Stop) 1/4”UNF (7/16” Head)
Clutch Cover
• 8 x Bolts 5/16”UNC (1/2” Head, 1” Long)
• 8 x Washers 5/16”SPR (1/2” OD)
• 8 x Washers 5/16”PLN (5/8” OD)
Tappet Chest
• 2 x Bolts 5/16” UNF (1/2” Head, 1 1/4” long)
• 2 x Washers 5/16 PLN (5/8” OD)
Pre A+ Distributor Drive
• 1x Bolt 1/4”UNF (7/16” Head, 3/4” long)
• 1x Washer 1/4”SPR (3/8” OD)
Fuel Pump
• 2 x Bolt 5/16” UNC (1/2 Head , 1 1/2”long)
• 2 x Washers 5/16” SPR (1/2” OD)
• 2 x Washers 5/16” PLN (5/8” OD)
Oil Filter Housing
• 2 x Bolt 3/8” UNC (9/16” Head, 1” Long)
• 2 x Washers 3/8” SPR
• 2 x Washers 3/8”PLN (15/16” OD)
Manifold Bolts
• 6 x Bolt 5/16 UNF (1” Long)
• 6 x Washers 5/16” SPR (1/2” OD)
• 6 x Washers 5/16” PLN (5/8” OD)
PostPosted: Tue Jun 08, 2010 6:26 pm
Sorry if this is a hijack of the post, but talking about nuts and bolts, I've removed every nut and bolt from my shell and parts and they've all been rust affected.
I've wire cleaned them all but does anyone know a way to prevent rust from reforming. I was trying to save money by cleaning them up and not buying new ones.
1968 Mini-Matic ex998 Now 1098
PostPosted: Tue Jun 08, 2010 6:30 pm
Drop them in to be zinc plated. Make sure they are normalised in an oven after plating (the plater will usually do this anyway..but ask) and make sure you get the quote first. Barrel lating is cheapest, all the nuts and bolts are dropped in at once to be plated. Other techniques have the individual nuts and bolts wire tie up and dipped...nice consistant finish but lots more $$.
PostPosted: Tue Jun 08, 2010 6:46 pm
I ordered 2 kits of nuts and bolts and screws from sc parts in the UK in October last year, they arrived this week! Only 8 mths delay, never answered any of my emails then just sent them and debited my c/card :evil:
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Tue Jun 08, 2010 6:55 pm
Mini King has sets of nuts, bolts, washers, screws, etc. in a plastic box. Most were collected from the floor of the BMC/Leyland production line, according to John Smidt. It's shown in his catalogue.
PostPosted: Tue Jun 08, 2010 7:15 pm
In spite of your glowing recommendation ;) what was the approximate cost?
PostPosted: Tue Jun 08, 2010 8:46 pm
I'm simply crazy about nuts, guys :wink:
PostPosted: Tue Jun 08, 2010 8:55 pm
Tomboss Breweros
I'm with GT, you'd be suprised at the price of a new box at a fastners shop.
Otherwise, if you are after a bit of a random assortment you can pick through when you loose or damage something, go to a wrecker and ask if you can pick aa bunch from an imperial bolted car, they shouldn't charge much.
When i go to U-pull it (local diy wrecker) i always have a decent handful of little bits that might be useful end up in my tool box, they'll never know :wink:
kimini wrote:
Jimmyinamini wrote:
PostPosted: Tue Jun 08, 2010 8:56 pm
Welcome to Ausmini and thats a first post.
Hope you Diggit (:lol:) "inside Joke" in here
