It is currently Sun Jul 27, 2025 10:59 pm
PostPosted: Thu Jun 17, 2010 5:45 pm
I'd like to know what torque settings should be used for the subframe mount bolts/nuts (if there is any specific settings) for 1978 Clubman
Front subframe :
Tower nuts (for pair of tower bolts)
Front bolt/nuts
Rear Subframe :
Bolts into heelboard
Bolts through floorpan
Also, I need to replace all the bolts so should all these bolts be high tensile?
Thanks.
-Alan
PostPosted: Thu Jun 17, 2010 6:00 pm
The Tower Nuts should be nylocs so they should be tight, they cannot be set with a torque wrench.
All other Nuts/ Bolts for the front subframe should be 18-20 ft/lbs.
All rear Subframe to Body bolts and nut / bolt sets are also 18 - 20 ft/lbs.
I've never bothered to torque them, just make sure they are adequately done up.
The original fasteners were Grade 5 tensile (3 straight lines on the bolt heads) and these are fine.
PostPosted: Thu Jun 17, 2010 6:16 pm
GT mowog wrote:
The Tower Nuts should be nylocs so they should be tight.
according to who?
the ones on my car are definitely not nylocs, they are standard nuts with a steel locking "tab" that goes underneath.
and the subframe has never been out of the car.
however it is an early mini, the later ones might have changed to nylocs. i couldn't tell you for certain though, as i don't own any wind-up window minis.
PostPosted: Thu Jun 17, 2010 6:21 pm
greyghost wrote:
according to who?
According to Leyland.
Yes early cars were fitted with normal nuts and these would have been torqued to 18 - 20 ft lbs. I don't know exactly when they changed to nylocs. The sheet metal thingy they put under these nuts has locktabs for the early cars.
<EDIT> There was also a brief time when Bolts were used in the towers in the Oz assembled Minis
PostPosted: Thu Jun 17, 2010 6:55 pm
I've had cars with all three varieties, the nylocs are the easiest IMHO
Jacob
PostPosted: Thu Jun 17, 2010 7:24 pm
re the 4 rear ones in the floor, I found they tend to come loose on my road car (even with new spring washers), and I got sick of retightening them.
They now have locknuts on em. I guess putting nylocs there would work too.
