It is currently Wed Jul 23, 2025 1:54 am
 Post subject: Morris 1100???
PostPosted: Mon Apr 18, 2005 1:04 pm
I know bugger all about the cars but there is a chance i can score a morris 1100 (non mini) what are chances I can grab parts for my mini off it?
Just wonderin if they used the same motors etc.
If not might still get it as apparently just needs a new front seat.
If it squeaks and leaks, then its sure to be a mini
Building a dream one nap at a time....
http://spaces.msn.com/members/derbydog/
PostPosted: Mon Apr 18, 2005 1:07 pm
Motor and gearbox can be used in a Mini (you would want to change the diff ratio from 4.26 or whatever).
Not much else..
PostPosted: Mon Apr 18, 2005 1:09 pm
Brakes could, but need modifications.
PostPosted: Mon Apr 18, 2005 1:11 pm
arent the outer cv joints the same as a cooper s? or am i mistaken?
72 Clubbie - Current project - Vauxhall C20XE 2000cc 16v 150hp.
78 Clubbie - Future project.
PostPosted: Mon Apr 18, 2005 1:24 pm
Yeah the CVs are, but not the rest- swivel hubs etc..
 Post subject: Door Handles
PostPosted: Mon Apr 18, 2005 3:23 pm
Internal door handles can be the same!!....I also think a few of the electrical acessories as well....master cylinders are larger volume but still OK....
Hydro bags....were they the same? anyone??
PostPosted: Mon Apr 18, 2005 3:36 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
from mamery :D yes
makka
PostPosted: Mon Apr 18, 2005 4:00 pm
from mamery :D yes
makka
from the one I checked out in a wreckers as far as I remember the 1100's Hydro bags were bigger than the minis :cry:
Roads need more corners
PostPosted: Mon Apr 18, 2005 4:12 pm
Hydro bags are way too big. :cry:
PostPosted: Mon Apr 18, 2005 10:53 pm
Thanks guys, interesting stuff, might have to get the bugger just for an engine upgrade.
PostPosted: Tue Apr 19, 2005 9:50 am
hydro bags are great big woopers of things... way to big for mini.. i checked b4 i dumped the remains of my 1100...
handles were good, some switches still looking at using the discalipers with s disc under 10's.. i grabbed the tin brake and clutch cans.. headlights, water overflow tank
think thats about it
PostPosted: Tue Apr 19, 2005 12:30 pm
you can actually use the radiator as well if you like,,,it`s way bigger (taller & wider) & will """Just"''' fit in a round nose,,,some bodys will need a slight mod depending on if it`s been in an accident allready, but on top of that only the bonnet safety catch needs a slight bend to the side & Bob`s your Aunty
if you wanted a big rad for extra cooling then this rad is really RAD :-)
The CVs are the same dimentions as "S" ones & therefor will fit & do the same job,
The rest of the brakes & swivel hubs are no good at all,,,i`ve known some people to mod them to fit but i personally wouldn`t bother,,,too much agro & not a pretty mod
The hydro bags are not the same & won`t fit at all,,,the internall door handles & various other tit bits are usable tho
the gearbox is usable but not really recomended as DrMini says, the diff ratio & diff housing are no good,,,& i`m not a big fan of that early 3 speed syncro "A" type box anyways,,,the later 1100"S" "B" type box is still a 3 speed but is a better set of gears & a far better case & can be used for the close ratio S/C C/R gear kit,,,but that`s only the 1100"S" type case,,,not the std 1100 case YUK!!!
headlights,,,& radiator expansion tank & master cyls & & & lots of other little goodies can be used also
PostPosted: Tue Apr 19, 2005 12:31 pm
Oh!!! & the steering column can also be used if you wanted a slightly longer one :-)
