It is currently Sun Jul 27, 2025 2:51 am
PostPosted: Mon Jul 05, 2010 5:09 pm
I have seen some car with a rubber strip along the back channel of the engine bay, where the bonnet sits.
Is this a factory thing?
What was the purpose?
Does it cause rust?
Is it available or do you just buy it from a rubber shop? What size is it?
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Mon Jul 05, 2010 5:17 pm
It is a standard factory item:
http://www.minisport.com.au/prod1372.htm
or get your own from Clark Rubber.
PostPosted: Mon Jul 05, 2010 5:58 pm
There was two different types, one for the roundie and one for the clubbie style.
PostPosted: Mon Jul 05, 2010 6:21 pm
what does it do?
PostPosted: Mon Jul 05, 2010 6:24 pm
Cuts noise, vibration, water splashback, and in the case of most rovers: the rust.
:D
PostPosted: Mon Jul 05, 2010 6:44 pm
NG wrote:
what does it do?
It stops oil from getting sucked from the engine bay onto the windscreen. :wink:
PostPosted: Mon Jul 05, 2010 7:08 pm
Adds weight, run without it.
PostPosted: Mon Jul 05, 2010 7:11 pm
lol shush you.
clark rubber sells this?
PostPosted: Mon Jul 05, 2010 7:13 pm
NG wrote:
lol shush you.
It's just a rectangular section sponge, Clark rubber should have it, I got mine from Grippy Rubber in Silverwater (Sydney).
1M is enough, then trim it to fit in.
PostPosted: Mon Jul 05, 2010 7:25 pm
The roundies have the square section rubber but the clubman has the h shaped one that fits on the front lip of the gutter.
PostPosted: Tue Jul 06, 2010 6:49 pm
$3.29 well spent.
It cut down a shocking vibration that only happened at idle.
Ryan Filippi
Minis In The Gong
[email protected]
