It is currently Sat Jul 19, 2025 12:57 pm
PostPosted: Fri Jul 23, 2010 8:21 pm
This is a diagram of a Morris 1100 horn from the workshop manual.
Is the Mini horn the same?
PostPosted: Fri Jul 23, 2010 8:24 pm
It is almost the same. The way the contact in the top of the column sits and the way the button works are different but the layout is similar.
PostPosted: Fri Jul 23, 2010 8:31 pm
Does the Mini have a spring loaded contact coming up through the middle
of the column?
PostPosted: Fri Jul 23, 2010 8:35 pm
of the column?
Yes, but it pokes up further than the 1100 one.
PostPosted: Fri Jul 23, 2010 8:39 pm
of the column?
Ah, good. Could you give an estimation of how much further....would be just a couple of mm?
PostPosted: Fri Jul 23, 2010 8:42 pm
From memory about 10 to 15mm further. The plunger and spring under the contact are much longer.
PostPosted: Fri Jul 23, 2010 8:46 pm
That's quite a bit.
Thanks again Morry for your usual encyclopedic knowledge.
