It is currently Sun Jul 27, 2025 9:11 pm
 Post subject: Setting tappet clearance
PostPosted: Sat Aug 07, 2010 11:18 pm
I am in the last stretch of getting the engine running again. I am having difficulties setting the tappet clearance though. Have read gafmo's guide in the how to section.
My problem is when I try to get the crank moving by having it in 4th and pushing, I just can't push it, it won't budge easily or at all.
Before you ask I did not have the handbrake on and it moves freely in neutral, spark plugs are out also.
Any hints?
1965 Morris Mini Deluxe - 998cc SC12
PostPosted: Sun Aug 08, 2010 12:39 am
Push harder? Your really just trying to rock the car not push it.
PostPosted: Sun Aug 08, 2010 12:41 am
Maybe crank it over a few times to get some oil around it?
Copper 4 lyfe!
PostPosted: Mon Aug 09, 2010 10:53 am
You say "getting engine running again" have you done something to the engine which may have seized it? Try turning the flywheel or the front pulley. If the crankshaft turns, then do as Hanra suggested, push harder.
PostPosted: Mon Aug 09, 2010 11:06 am
Any hints?
Handbrake wont make a difference, only works on rear wheels. If you are near the rear wheels during any of this process you are doing it wrong.
Is the front of the car jacked up ?
Having it in fourth gear means you need to turn the wheel of the car while the front is off the ground
You won't be moving anything with 4th engaged and the wheels on the ground.
PostPosted: Mon Aug 09, 2010 5:11 pm
try this car in gear 4th if you like foot on clutch
have a mate push the car once moving release clutch
PostPosted: Mon Aug 09, 2010 5:25 pm
I can't believe u all do it that way!! Just turn the motor over from the engine bay with a spanner.. U don't have to keep moving around then, and you can see when the motor is in the correct spot!
Potato
PostPosted: Mon Aug 09, 2010 5:55 pm
just grab the belt!
PostPosted: Mon Aug 09, 2010 11:38 pm
stand in front of the car, push back slightly first then pull forward towards you
PostPosted: Mon Aug 09, 2010 11:53 pm
Any hints?
err...
if you have the front of the car off the ground, you have to turn BOTH front wheels... try doing that on your own! :P
and yes, you can push the car in fourth, just rock it a bit to build up some momentum. take plugs out too should make it easier.
tim
PostPosted: Tue Aug 10, 2010 7:11 am
Yeah, I didn;t really make that very clear. I meant one side.
PostPosted: Tue Aug 10, 2010 10:22 am
Will try harder again tonight :oops:
Users browsing this forum: No registered users and 68 guests
