It is currently Wed Aug 13, 2025 8:47 pm
PostPosted: Wed Aug 11, 2010 6:58 pm
Hi just fitting new rings and am having trouble with oil ring they are 3 piece hastings ive not come across these before there is a spacer 1 ring and a 8 sided spacer i'm totally lost with how they go as the instructions on leaflet doesn't show how they fit any help appreciated
Darren
00 triton d/cab
55 chev(oversize moneybox)
1963 850 (roundie)
77 clubby
95 zxr 750 + toys!!
PostPosted: Wed Aug 11, 2010 7:02 pm
8 sided ring goes in first.
Then the spacer ring
Then you peel the 2 scraper rings on, working down from top of piston, 1 goes each side of the spacer ring.
PostPosted: Wed Aug 11, 2010 7:06 pm
thanks doc thats what i thought but only one scraper ring for each piston in the box there were 4 of each spacer and 4 scrapers 12 pieces total
Darren
00 triton d/cab
1963 850 (roundie)
77 clubby
95 zxr 750 + toys!!
PostPosted: Wed Aug 11, 2010 7:10 pm
Be sure that you don't accidentally over-lap the ends of the 8 sided ring
PostPosted: Wed Aug 11, 2010 7:13 pm
sounds wrong to me, isn't there a data sheet with pics in the box? If flat chromed scrapers, there should be 8 there.
PostPosted: Wed Aug 11, 2010 7:21 pm
youre right doc just went over to shed and checked the box and instructions on packet said 1 on top and 1 on the bottom! here's another wait for 4 more,i can't seem to take a trick latley :lol:
Darren
00 triton d/cab
1963 850 (roundie)
77 clubby
95 zxr 750 + toys!!
PostPosted: Thu Aug 12, 2010 7:49 pm
went back into parts shop today and explained what was missing and after a few calls to mainland supplier salesman was told that it wasn't the only set with 4 oil scraper rings instead of 8 :roll: packer must have had a bad day!!!! :oops: another set was sent this afternoon so i will have them tomorrow
Darren
00 triton d/cab
1963 850 (roundie)
77 clubby
95 zxr 750 + toys!!
 Post subject: Oil Rings
PostPosted: Fri Aug 13, 2010 4:24 am
Lucky you noticed and investigated it or you would have ended up with a very oily outcome.
"Let us remove your "SHORTS"
Users browsing this forum: No registered users and 251 guests
