It is currently Wed Jun 25, 2025 2:12 pm
 Post subject: where to lube...?
PostPosted: Thu Sep 30, 2010 6:45 pm
Milatsmadmini
changing bottom arms at the moment, got some adjustable with nolathane bushes, where do i put the dark thick lube stuff, obviously in the whole where the pin goes, do i also lube up the inner shell where the bush is?
PostPosted: Thu Sep 30, 2010 6:59 pm
All depends, if you get it real excited you wont need any lube :lol: :lol:
 Post subject: Re: where to lube...?
PostPosted: Thu Sep 30, 2010 7:11 pm
Yep, and plenty of it. It helps to let the bushes work properly & last longer.
PostPosted: Thu Sep 30, 2010 7:21 pm
They need lube because unlike the rubber originals, `Nolathane' (polyurethane) won't work as a `live' rubber (ie bonded) bush. it splits.
Users browsing this forum: Bill B and 99 guests
