It is currently Mon Jul 21, 2025 7:03 pm
PostPosted: Mon Oct 04, 2010 8:13 am
I have had a look through my owners manual and i cant seem to find what i should torque the main nut on the wheel hub up to??
any help would be greatly appreciated!!
Hi-Ho Silver LS1275
PostPosted: Mon Oct 04, 2010 9:12 am
With drum brake CVs it's 60lb/ft then align to the next pin hole.
With disc brake CVs (Cooper S onwards) it's 150lb/ft then align to the next pin hole.
PostPosted: Mon Oct 04, 2010 9:58 am
Once again thank you doc! you seem to be a major helping hand in getting this LS back on the road!!!
(it was the front end so its the disc brakes)
Hi-Ho Silver LS1275
PostPosted: Mon Oct 04, 2010 1:38 pm
Mods rock!
If the (Disc type) CV has two holes through it as the Doc says^ but if it has one hole and a course thread for the split pin it's actually 193 ft/lbs and then to the next hole.
Users browsing this forum: Barkfast, Bing [Bot] and 84 guests
