It is currently Thu Jul 31, 2025 9:21 am
 Post subject: Will it pass????
PostPosted: Fri Nov 19, 2010 3:43 pm
Hey guys
I'm the proud owner of my second little car. A 67 deluxe (which i promise i will put pictures up when i get to it). The girl is original and i want to keep it that way.
Quick question, i hope. I have done a general check on her, changed points and plugs. Runs great and starts every time. Issue is that there is a small oil leak coming from the back, could be from the tappet covers. Very small, one drop or so and she blows a little smoke. A tinge of white. Now, eventually i want to take the engine out and rebuild but i would love to get her registered so i can drive her around to a mechanic to get the work done.
With these slight issue's what are my chances on passing blue slip in NSW?
Thanks
PostPosted: Fri Nov 19, 2010 3:57 pm
Most places will pass it on oil leaks as long as it doesn't drop any oil on their workshop floor while they are doing their inspection. I'd say you'd be sweat as it's not a car that draws un-necessary attention, like a V8 ute with a juke box in it.
PostPosted: Fri Nov 19, 2010 4:10 pm
you will be fine. but as GT said make sure no oil leaks on there floor. keep a rag in your pocket so you can quikly wipe it up.
PostPosted: Fri Nov 19, 2010 4:17 pm
Dont go to a non-mini mechanic....
Mini mechanic = "I know these old girls and boys leak oil, you're taking care of the car... PASS"
Non mini mechanic = "I am going to totally f__k your engine up trying to stop an oil leak that is going to exist no matter what just to make you come back time and time again because your car is all of a sudden not working well"
GO... TO.... Mini.... mechanic.
if nothing less they might be able to fix your leak better than any non mechaic will
PostPosted: Fri Nov 19, 2010 4:30 pm
i can not agree more strongly with the mini mechanic statement...
first car bought unregistered and took it just to a normal mechanic and had to go back another 2 times before it passed
second car bought it from victoria (needed blue slip) went to mini mechanic and passed straight away, rebuild her she got unregistered again sent it to a mini mechanic and passed blue slip straight away again
GO TO A MINI MECHANIC!!! :lol:
Hi-Ho Silver LS1275
PostPosted: Fri Nov 19, 2010 7:16 pm
Mini mechanic??????
Regional Canberra. Anybody know of a mini mechanic out regional NSW near Canberra?
PostPosted: Fri Nov 19, 2010 7:33 pm
Just drain all the oil out of iT ...Then you can take it anywhere.. :D
PostPosted: Fri Nov 19, 2010 7:55 pm
Cancillier Motors Qbeyan. Doc's a Corvette man but he "understands" Minis. Tell him Ian sent you..
PostPosted: Fri Nov 19, 2010 9:44 pm
Ps I wasn't saying mini mechanics were any easier etc etc..... They just know what to fix to make sure you are back on the road without much stuffing around
PostPosted: Sat Nov 20, 2010 6:01 am
Actually my experience has been the opposite. The non-mini mechanic doesn't know what to specifically look at or where to look, so if they don't know what they are looking at, easy.
Just make sure they don't try to jack up the front end by putting the jack under the floor :twisted: I have probably told our local (moron) guy close on 20 times now and many many times every year, but he still goes to do it.
Users browsing this forum: Goldbrocade_62 and 87 guests
