It is currently Sat Aug 16, 2025 4:40 am
PostPosted: Sun Nov 21, 2010 8:04 pm
Just trying to set up my dizzy with a test light, i got the engine sitting at 5 deg BTDC and have fitted a test light to coil, if i rotate dizzy it light stays on , there is a short break point where no light is on but looks to me like the light is on for 1/4 turn of the dizzy
what am i doing wrong
PostPosted: Sun Nov 21, 2010 8:07 pm
I gather 5dbtdc is the manufacturers recommendation?
The simonBBC one I have is 10dbtdc...
Alec
PostPosted: Sun Nov 21, 2010 8:12 pm
Also sounds like you need to adjust yr point gap........
its just a starting point , new motor, just want to kick it in the guts ane run the cam in , i will adjust with strobe light once running
PostPosted: Sun Nov 21, 2010 8:13 pm
Points on an electronic dizzy? Am I missing something? :shock:
Alec
no points, its been converted by tony
PostPosted: Sun Nov 21, 2010 8:20 pm
I just took it from your thread title 'electric' dizzy, I 'guessed' that you would have written 'electronic' if that was (and turns out is) the case.
PostPosted: Sun Nov 21, 2010 8:24 pm
no worries my bad
still want to know how to tell at what point the rotor and the cam/magnet actually shoot the power to the spark plug????
PostPosted: Sun Nov 21, 2010 8:29 pm
Not knowing what type of electronic set up it is, it would normally be - as you rotate the dizzy body clockwise - just as the lamp goes out.
PostPosted: Sun Nov 21, 2010 8:31 pm
With some electronically switched dizzies you can use a small radio (tranie :) to pick the switch point. Tune the radio off station, place it beside the dizzie, rotate dizzie as you would to set conventional points and you will hear a burst of static as the switch fires.....
Cheers, Ian
PostPosted: Sun Nov 21, 2010 9:02 pm
It's the same electronic module I'm using:
You only need it nearly right to get it to start.
Put motor on TDC, #1 firing.
Mark the #1 plug lead's position on the dizzy body.
Turn dizzy until rotor lines the mark up.
Turn the body ~3mm clockwise. Refit the cap.
Start it and use your timing light.
PostPosted: Sun Nov 21, 2010 9:05 pm
http://www.ausmini.com/forums/viewtopic.php?t=53920
this type of set up
PostPosted: Sun Nov 21, 2010 9:25 pm
the end of the rotor buton is very wide at what point does the rotor and cap trigger the connection
PostPosted: Sun Nov 21, 2010 10:00 pm
Craig, do what the Doc said,,, put it "pointing" at number one & it`ll run
then set it with the timing light
PostPosted: Mon Nov 22, 2010 6:53 pm
did what the doc siad, started after 4 cranks, thanks for the quick and professional help.
i have only ran at 2000 rmp so far , running in the cam.
i will connect up the exhaust and take it for a blat to bed in the rings
Users browsing this forum: No registered users and 368 guests
