It is currently Sun Aug 17, 2025 2:44 pm
 Post subject: Hook n Up timing light.
PostPosted: Fri Nov 26, 2010 10:18 pm
Greetings All.
Finally finished my 850 project. Motors all rebuilt, new plugs, points, cap leads etc etc....
Im aware of the port hole and flywheel timing marks, however...?
For my timing light it requires + battery, and I can earth from block. I have a + direct from battery for driving lights. It's not a bright flash like normal? And I can't get a direct point to the timing marks, as the timing light has too big-a pistol type handle. Is there a how-to somewhere I can read up on? If the flash was stronger, would a mirror be the way?
(do the timing, fit the new muffler,bonnet, wiper blades, give it another wash and I'm ready to post a pick (yahoo!)
Alex.
PostPosted: Fri Nov 26, 2010 10:33 pm
just did mine today, used a mirror flashed my long timing light into hole and leaned over the pass side guard over radiator to back of engine to get a peak at the marks
PostPosted: Fri Nov 26, 2010 10:42 pm
Thanks Dodge.
I'll try and do it in the dark so I can see better. Have graded lens's in my specks and it's damm hard to get everything in line. (I'm not as flexi as I used to be!)
Alex.
 Post subject: Ignition Timing
PostPosted: Sat Nov 27, 2010 4:27 am
Hey Dodge, How did the Modified Cooper S Distributor that I made for you go?
"Let us remove your "SHORTS"
PostPosted: Sat Nov 27, 2010 8:05 am
very good, was hard to work out what point it makes contact tho. but its running now and i will get ready to tune it next week. i will to bring the car to you for a wiring check over, some things are not working, but i think its because the new indercator lights only had 2 wires no earth wire
Users browsing this forum: Majestic-12 [Bot] and 350 guests
