It is currently Tue Aug 12, 2025 10:04 pm
Yes I've done a non verto to verto and I would:
Recommend it for a lighter clutch pedal 67%  67%  [ 4 ]
NOT recommend it for a lighter clutch pedal 33%  33%  [ 2 ]
Total votes : 6
 Post subject: Pre- Veto to Verto
PostPosted: Wed Dec 01, 2010 5:48 pm
Hi all. Further to my last post, GT mowog has suggested I consider changing to a verto clutch as my car is a road car only and sub 100hp.
So the question is: has anyone done one of these conversions and does it give a lighter clutch pedal than a standard mini one. (If you haven't can you avoid posting please except for links to someone who has)
The motor is a 12H series 1275. If anyone has a similar engine with a verto conversion on Brisbane northside I could test drive that would be even better. I am at Strathpine.
Thanks in advance.
Alec
PostPosted: Thu Dec 02, 2010 4:01 am
I have not done a conversion from non-verto to verto but I have driven many minis with both types of clutch fitted.
From my experience the verto clutch is much lighter to operate than the earlier non-verto type.
PostPosted: Thu Dec 02, 2010 8:45 am
You could get all the verto parts from one of the thousands of people who have done the conversion the other way. :)
Another option is to fit a brake booster to the clutch. It may sound weird but it works well. Its good for people who don't have strong legs.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Fri Dec 03, 2010 8:35 pm
Simon K's input:
"I wonder if you can't make your pedal lighter by checking and adjusting the diaphragm as per this article: http://www.minimania.com/web/DisplayID/ ... ticleV.cfm
if the diaphragm isn't set up properly, your foot needs to compress the spring, which makes for a hard pedal. If it is set up properly, the spring is pre-compressed, which makes for a soft pedal, with significantly improved clamping pressure
For reference, I have a supercharged 1275 with a standard clutch, and my 13 year old daughter drives it without needing to strain on the clutch
cheers,
Simon"
Alec
PostPosted: Fri Dec 03, 2010 9:18 pm
Mods rock!
1275LS wrote:
Simon K's input:
cheers,
Simon"
Hmmmm.......did Simon also mention that his daughter is a champion althete too?
PostPosted: Fri Dec 03, 2010 11:36 pm
GT mowog wrote:
1275LS wrote:
Simon K's input:
cheers,
Simon"
watch it... or she'll kick you!
PostPosted: Sat Dec 04, 2010 10:31 am
Yep it is a Shitttttt load lighter just do it you won't look back.
I have a at up I can sell you as I have a new clutch and fly set up
Only done 10ks as I updated my vert for a blower.
I'm at boondall northside we have 2 rovers minis you can try the pedal on.
PostPosted: Sat Dec 04, 2010 11:12 am
When I replaced the clutch in my Morris 1100 about two years ago I fitted a Cooper S clutch and pressure plate. Big mistake!
The Cooper S diaphragm it a lot stiffer to push than the stock one.
If you don't have a powerful motor and never get clutch slip just use a stock pressure plate.
PostPosted: Sat Dec 04, 2010 12:10 pm
Mods rock!
simon k wrote:
GT mowog wrote:
1275LS wrote:
Simon K's input:
cheers,
Simon"
:shock:
PostPosted: Sat Dec 04, 2010 6:35 pm
If the diaphragm is set up flat on assembly an S one is pretty light, so is an orange dot one.
They get heavy to push when the assembled height is too great due to flywheel and backplate wear.
I dislike the engineering of the Verto, the flywheel is not attached to the crankshaft, but the diaphragm spring is. :shock:
It is much heavier, and its only advantage? is a lighter pedal + less force on the crank thrust washers.
Users browsing this forum: 1071 S, Bing [Bot], norton and 312 guests
