It is currently Mon Jul 28, 2025 10:42 am
 Post subject: LS Badges
PostPosted: Tue Dec 14, 2010 9:17 pm
Does anyone know how the L & S badges are fixed to the grill on a Leyland Mini LS . Have been told that they use the same plastic inserts as the boot badges ??? , but there aren't any holes in the grill ....cheers
PostPosted: Tue Dec 14, 2010 9:24 pm
The holes should be there if it is the original LS grill, if not it has been replaced at some point. Just drill some new ones and pust the mouse condoms into the new holes :D .
Have a Nice Day.
PostPosted: Tue Dec 14, 2010 11:19 pm
Exactly what 850man said. When pushing them in you need to support the back though as the grill will let them slip through if the hole is slightly oversize.
Let me know if you need a hand with the correct location. Mind you the factory may have just guessed them in :D It was Leyland after all :lol:
Alec
PostPosted: Wed Dec 15, 2010 11:00 pm
Hope this helps :D
PostPosted: Thu Dec 16, 2010 3:02 pm
I can measure the location of mine as well, might be able to get an average??
1978 1275LS HIHO Silver with 13 x 7 Superlites
1972 Clubman GT Ex NSW Police HWP
1971 Clubman 4EFTE powered
PostPosted: Thu Dec 16, 2010 5:54 pm
Hey all
Im in the same situation, any measurements would be greatly appreciated
1978 1275 LS silver 3rd palce mini Oz50 LS,SS,GT Class
1970 MORRIS MINI K 1100 3rd place mini50 pre '71 Class
Rover BBQ..... ;)
PostPosted: Thu Dec 16, 2010 6:10 pm
Here is a couple of photos that may help, they are from the grill of my 1275LS that I bought in 1984 and I think it is the original grille.
The tape measure is sitting on the centre of the stud that holds the middle badge in place, it is as close to centre as I can get it without removing the badge.
As you can see the badges are poked into the little plastic condom which are poked into the grille.
PostPosted: Thu Dec 16, 2010 7:30 pm
Thanks for the replies guys , mustn't be the original grill then as it doesn't have any holes ....cheers
