It is currently Thu Jul 24, 2025 1:07 pm
 Post subject: How do I remove this?
PostPosted: Sat May 07, 2005 9:37 pm
Hi all,
Not sure if I'm missing something obvious here, but I've been trying to remove these two pieces from the rear subframe with no luck. This picture shows the offender (The round thing with 2 holes that seems to have a bolt that goes all the way through (shown in picture 2) :
I've tried hitting the end of the bolt shown in picture 2 to knock the thing out, but it won't budge. I can't turn the round thing to unscrew it either. Is there a tool that locks into the two holes?
Any help would be appreciated.
LG
PostPosted: Sat May 07, 2005 9:47 pm
multi grips on the round part.
Sounds like it might be seized. give it a squirt with wd40 or similar, then try to turn it with the multi grips. that should loosen it and let you remove it.
PostPosted: Sat May 07, 2005 9:50 pm
Thanks JAM - so it is meant to unscrew then? Or is the twist you recommend just to loosen?
PostPosted: Sat May 07, 2005 10:01 pm
It unscrews... there's a nut on the inside of subframe, under all the crud.. :lol:
PostPosted: Sat May 07, 2005 10:07 pm
cheers guys - now all I gotta do is get some multi grips......
PostPosted: Sat May 07, 2005 10:10 pm
the nut is off in that pic.
i am suggesting you try to turn it, to loosen it. It doesn't unscrew once the nut is off, it slides out.
PostPosted: Sat May 07, 2005 10:13 pm
Jeez Anton your eyesight is better than mine, pic is too dark to see if nut is there or not!
Anyhow the bolt is pretty small diameter shank, check it's not bent when it's out. :wink:
PostPosted: Sat May 07, 2005 10:18 pm
To confirm, the visible bolt is nutless.
PostPosted: Sat May 07, 2005 11:17 pm
I think you will find the Bolts are bent and will need replacing...when you have got them out of Course :?
