thanks guys,
after all this my mate decided we would go ahead and throw the subframes in so we can roll the body in and out of the garage. . probably not the best thing to do first but they come back out easy anyway.
during this process i discovered i have two front subframe bolts for the hydro towers. . . that's it. . 0_0 the rest is held in with random things currently to keep it rolling. I think i need to buy that 'mini in a box' bolt kit mentioned above.
the 1098 is bolted to the subframe on brand new engine mounts also.
i think my next step is going to be pulling the hand brake from the 'parts wreck' that never seems to have the parts i need
(no subframes in it so no subframe bolts/parts i needed) and fitting that all up, and ill have to go buy a length of power wire for the positive run from the Battery to the engine bay as I do not have that.
other question though, my steering rack is just chilling out not bolted in. . how do these bolt in? im either stupid or blind (or both!) and could not see any obvious mounting bolt holes on it? u bolts or something is it?
other thing ive found I need is full CV's to go from the deluxe front drums into the splines on the 1098 diff/gearbox as I have none. . . best place to source these? serviceable second hand will do me fine as long as they fit in the car.
Leroy.
1967 Mini Deluxe bucket of rust and mismatched parts powered by a 1360cc and a destroyed gearbox missing second gear
