It is currently Sat Aug 02, 2025 11:03 pm
PostPosted: Fri Apr 29, 2011 2:02 am
Hi,
I'm trying to find out who the manufacturer is of my wheels.
The outer edge is polished bright.
Any ideas?
It seems a bit different than the standard Minilite.
Thanks.
Image[/img]
1970 Mini K with 1275s.
PostPosted: Fri Apr 29, 2011 2:44 am
The manufacturer is ROH.
The wheel is called Contesta and also Contessa, depending on where you look. I *think* that they were also marketed in the 1980s under the brand name Cheviot.
These are a popular aftermarket Mini wheel, but are no longer available new.
They were standard fitment on the Mini SS, and a slightly different version was standard on the Mini LS 998 (different offset).
EDIT: Just noticed that you're in the States.
It might be worth adding that these are Australian-made wheels, so while they are popular down here they are probably somewhat rarer in the northern hemisphere.
PostPosted: Fri Apr 29, 2011 5:59 am
Thanks for the reply.
 Post subject: These wheels
PostPosted: Sat Apr 30, 2011 6:11 am
I have a bout three spare sets of these Wheels in the Shed.
"Let us remove your "SHORTS"
 Post subject: Re: These wheels
PostPosted: Sat Apr 30, 2011 9:37 am
I have some with ROH clearly marked on the inside and some without, so I think there may have been no name copys out there too. As others have said they were/are pretty popular here in Oz and seen with different offsets.
PostPosted: Sat Apr 30, 2011 10:40 am
These are the LS offset wheels. Same width as yours but they fit under the arches without the need for flairs.
PostPosted: Sat Apr 30, 2011 11:59 am
I've got a set on my van with the ROH factory centrecaps with red lettering. They're a reasonable wheel but the spokes are fatter than the more usual Minilite style.
My Rover has a set of 14 x 6 GB alloys made by BWA Racing ( Benzoni Wheels Accessories - Milano, Italy) who also produced them in 10x6 for Minis during the 1980s. These had fatter spokes than Minilites but not nearly as wide as the Contessas. They are also very light with hollow spokes. Minispeed last stocked them.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Sat Apr 30, 2011 12:08 pm
i need one to replace the one i borrowd from daughter 1.0
to sell to james holloway
who then nomimated me for mongrel :lol: :lol: :lol:
