It is currently Wed Aug 20, 2025 6:40 am
PostPosted: Wed Jun 15, 2011 6:39 pm
My gear stick constantly rattles and makes a terrible noise. I have replaced the bush that sits underneath the stick but that didn't fix the problem.
It is a matter of a worn remote/selector etc and I just need to replace the whole unit? or is there something else to look at?
Ryan
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Wed Jun 15, 2011 6:46 pm
Mods rock!
I did read somewhere a while ago that one of our local suppliers has a teflon bush that goes inside the remote shifter to sort it, but that only works if the complete remote unit is not too worn. There is a grease nipple on the front end of it, you can pump it with grease and that'll help for a little while.
PM sent.
PostPosted: Wed Jun 15, 2011 7:45 pm
Hi Ryan,
This previous post may help.
http://www.ausmini.com/forums/viewtopic ... +line+bore
PostPosted: Wed Jun 15, 2011 7:52 pm
with the engine off, push up on down on the stick. I'm thinking the Rubber mount at the end of the remote may need replacing
PostPosted: Wed Jun 15, 2011 9:42 pm
Can also be worth checking you don't have a mis-match of parts, there were a few different ways of retaining the lever & the dampening on the end, if the bits get mixed up it can sometimes never be right :?
Jacob
PostPosted: Fri Jun 17, 2011 5:29 pm
I just cut a bit of rubber and used it as a big washer
Stopped the shake and the metallic banging sound :lol:
ook!
69 mini k
Users browsing this forum: No registered users and 358 guests
