It is currently Thu Aug 07, 2025 11:48 pm
PostPosted: Thu May 26, 2011 9:07 am
hey guys , just a few question , my mini is getting harder to start in the morning , it use to start first go until i got it adjusted because it was running very rich , wasting heaps of fuel and blowing black smoke . should i richen it up a little ?
would there be and electrical problems , hence problems with my starter coil or leeds ? i couldnt be my alt cause i have just change it ...
can anyone suggest anyway that it would start up betta , it takes so long for it to start .
PostPosted: Thu May 26, 2011 9:18 am
How long is "so long"?
Mine has been getting a little harder to start as its getting into winter (just like me) but with full choke it still starts within 3-4 seconds. Then it needs a good warm up to get it going. Do you pump a little bit of accelerator as you try to kick it over?
PostPosted: Thu May 26, 2011 9:48 am
Mods rock!
Does your choke work?
 Post subject: Start
PostPosted: Thu May 26, 2011 10:08 am
I'm pretty sure the choke works , it feels like the engine doesn't have enough spark or petrol to crank over ! I have try 10 times before I get a paulse , I pump the gas a aswell . Once it starts it fine .
PostPosted: Thu May 26, 2011 11:01 am
Check your battery, just to be sure, cold & wet weather can sometimes affect the batteries performance.
My old purple clubbie was crap in the morning until I put a new battery with a higher CCA in.
PostPosted: Thu May 26, 2011 11:54 am
Crank it for a timed period (not guessed) and count revolutions. Post the result and somebody will soon squeal if it sounds too low.
PostPosted: Thu May 26, 2011 12:02 pm
Is your choke cable too loose? I had a problem where there was too much extra length of the cable at the carby end, and the choke didn't do anything at all until it was about 1/4 of the way out. This means when the choke is all the way out, it isn't as rich as it's supposed to be.
If you pull the choke out just a little, you should see the fast idle adjustment moving almost straight away. The jet lowering should start when the choke is about half way out.
 Post subject: Re: Start
PostPosted: Thu May 26, 2011 12:15 pm
minilee wrote:
it feels like the engine doesn't have enough spark or petrol to crank over ! I .
This sounds like you are trying to say it turns over slowly, is this what you mean :?: If so I would be looking at the battery.
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Thu May 26, 2011 6:26 pm
agreed
PostPosted: Thu May 26, 2011 7:28 pm
I would normally suggest pouring some hot water over the battery, if it then starts easier you know that is the issue. However, given the battery is in the boot.....
