It is currently Thu Aug 07, 2025 9:34 pm
PostPosted: Thu May 26, 2011 9:07 am
hey guys , just a few question , my mini is getting harder to start in the morning , it use to start first go until i got it adjusted because it was running very rich , wasting heaps of fuel and blowing black smoke . should i richen it up a little ?
would there be and electrical problems , hence problems with my starter coil or leeds ? i couldnt be my alt cause i have just change it ...
can anyone suggest anyway that it would start up betta , it takes so long for it to start .
PostPosted: Thu May 26, 2011 9:18 am
How long is "so long"?
Mine has been getting a little harder to start as its getting into winter (just like me) but with full choke it still starts within 3-4 seconds. Then it needs a good warm up to get it going. Do you pump a little bit of accelerator as you try to kick it over?
PostPosted: Thu May 26, 2011 9:48 am
Mods rock!
Does your choke work?
 Post subject: Start
PostPosted: Thu May 26, 2011 10:08 am
I'm pretty sure the choke works , it feels like the engine doesn't have enough spark or petrol to crank over ! I have try 10 times before I get a paulse , I pump the gas a aswell . Once it starts it fine .
PostPosted: Thu May 26, 2011 11:01 am
Check your battery, just to be sure, cold & wet weather can sometimes affect the batteries performance.
My old purple clubbie was crap in the morning until I put a new battery with a higher CCA in.
PostPosted: Thu May 26, 2011 11:54 am
Crank it for a timed period (not guessed) and count revolutions. Post the result and somebody will soon squeal if it sounds too low.
PostPosted: Thu May 26, 2011 12:02 pm
Is your choke cable too loose? I had a problem where there was too much extra length of the cable at the carby end, and the choke didn't do anything at all until it was about 1/4 of the way out. This means when the choke is all the way out, it isn't as rich as it's supposed to be.
If you pull the choke out just a little, you should see the fast idle adjustment moving almost straight away. The jet lowering should start when the choke is about half way out.
 Post subject: Re: Start
PostPosted: Thu May 26, 2011 12:15 pm
minilee wrote:
it feels like the engine doesn't have enough spark or petrol to crank over ! I .
This sounds like you are trying to say it turns over slowly, is this what you mean :?: If so I would be looking at the battery.
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Thu May 26, 2011 6:26 pm
agreed
PostPosted: Thu May 26, 2011 7:28 pm
I would normally suggest pouring some hot water over the battery, if it then starts easier you know that is the issue. However, given the battery is in the boot.....
Users browsing this forum: watsupskip and 102 guests
