It is currently Mon Jul 28, 2025 7:31 am
PostPosted: Thu May 26, 2011 6:36 pm
Hi all,
Today at rego check, I went to pump the washers to spray water and ....nothing.
I had a quick look and the lines were bone dry (its been a year since I last used them). I pumped and pumped but nothing came through?
Do I need to bleed the lines? When I take the tubes off the back of the pump it feels as though its sucking, but it was kind of hard to tell at the time.
Ryan
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Thu May 26, 2011 7:25 pm
Check the little valve on the end of the hose that is in the washer bottle?
PostPosted: Thu May 26, 2011 7:48 pm
the hose just drops straight into the bottle. No valve.
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Thu May 26, 2011 8:14 pm
Yeah I think it needs that little one way valve. Probably fell off last time you filled it.
I think one from an aquarium shop might work.
PostPosted: Thu May 26, 2011 9:16 pm
Ha, I will check in the bottom of the bottle?
What do they look like?
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Thu May 26, 2011 9:55 pm
Like an upside down mushroom with a flat head! :wink:
PostPosted: Fri May 27, 2011 4:26 pm
They usually look something like this...
PostPosted: Fri May 27, 2011 6:25 pm
I'll have to go and check mine now :shock: it hasn't worked since i've owned it :!:
PostPosted: Fri May 27, 2011 6:30 pm
You need to get all the air out of the pump for best results. It is a probably a good idea to remove the pump so you can turn it to get the air out while pumping.
The washers on my 1100 stopped working a while back and I found that the hose on the firewall had been hit by the air-filter splitting the hose.
PostPosted: Fri May 27, 2011 6:50 pm
In reference to my last post: Maybe not a mushroom then! :lol:
PostPosted: Fri May 27, 2011 6:53 pm
Where do the hoses go through the fire wall to the pump ?
Is there a certain hole there some were ?
is it below the parcel self ?
Mark
PostPosted: Fri May 27, 2011 8:44 pm
G'day Mark, from memory when i done a wiring job on my ignition under the dash , i remember the tube coming in through the dash with the main wiring harness , and down to the pump. Definately not saying that this is the correct route for it.
PostPosted: Sat May 28, 2011 6:48 pm
Thanks goodie , starting to put mine back together
Mark
PostPosted: Sun May 29, 2011 10:01 pm
These are the two listed on the minisport website.
Mini windscreen washer one way valve (early cars)
[/url]http://www.minisport.com.au/prod716.htm[url]
and
Mini windscreen washer valve (sits in washer pump bottle)
[/url]http://www.minisport.com.au/prod1870.htm[url]
I imagine the bottom one is the one I need. Whats the top one for?
Does $15 seem a little steep?
[/url]
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Sun May 29, 2011 10:59 pm
I look at it this way, if someone came to you and showed you the valve and said "if I give you $15 will you make me one of these?".....kinda makes it look like good value then! :)
