It is currently Mon Aug 18, 2025 3:28 pm
 Post subject: More Wiring headaches
PostPosted: Mon Jun 13, 2011 1:41 pm
Thought I'd finish off the wiring (loom is in just not all plugged together)
Started with the bunch of connectors near the wiper motor feeding the rear loom. - ended up with a green with brown trace on the front side ( ie switched power) and a purple on the rear side (interior light) Means the ignition has to be on to turn the interior light on does it not? :evil:
Next hooked up the lead that goes through the parcel shelf to the turn/horn lead out of the steering column - all matched up except I have a green with brown trace and a black left over :? Heater?
Also the horn wires are brown and brown with black trace (even the original wires I left in the stearing column yet the diagrams say they should be purple :? They don't make it easy.
PostPosted: Mon Jun 13, 2011 2:16 pm
Where did that harness come from?
PostPosted: Mon Jun 13, 2011 5:46 pm
Mob in WA via Northern Mini Spares about 8 years ago :roll:
PostPosted: Mon Jun 13, 2011 5:53 pm
Mmmmm....were they colour blind?
 Post subject: Where they Colour blind
PostPosted: Mon Jun 13, 2011 7:31 pm
Hey mr GT MOWOG. There is nothing wrong with colour blind people. For your info I AM ONE of those people too. But I have done Auto Electrics for the last 40 years or more. It is a problem sometimes but asking someone to help you ID a colour is easy. I am used to it. I know no different. I often rely on a Multimeter to see where wires go to when I can not identify the colours. Mind you I am colour blind with Green Red and Browns. Most common colour blindness.
"Let us remove your "SHORTS"
PostPosted: Mon Jun 13, 2011 7:46 pm
Hey Tony, not saying there is anything wrong with anyone. Just asked a question and yes, I am quite aware the those who are colour blind can still (usually) distinguish different colours!
It was a tongue-in-cheek quetsion as you would have to agree that for a (new?) suplied wiring harness to have wire that change colour at connections and even 'half way through' is perculiar to say the least.
PostPosted: Tue Jun 14, 2011 11:14 am
Worked it out (I think) - not colour blind - short sighted :roll: Green with brown trace is numeber 38 on the wiring diagram - Purple is number 28 - Just have to check now if that particular green with brown goes back to the fuse :wink:
As for the brown leads from horn push to horn - the very first English diagram has them as brown - all others since are purple :?
Users browsing this forum: No registered users and 285 guests
