It is currently Mon Aug 18, 2025 10:13 am
PostPosted: Tue Jun 14, 2011 10:30 pm
Open ended spanners with a ratchet
It exists.
Theyre crap.
Simplify and add lightness
PostPosted: Tue Jun 14, 2011 10:32 pm
Theres a link,
http://www.craftsman.com/shc/s/p_10155_ ... ockType=L1
I find they dont have a good enough angle to make them useful. And if the nut/bolt is rounded off they just keep slipping round.
Your local Bunnings may have some, were on special a while ago.
PostPosted: Tue Jun 14, 2011 10:33 pm
There are also ratchet shifters.
Again.....crap.
PostPosted: Tue Jun 14, 2011 10:36 pm
Again.....crap.
I will back that up. A bit like those crescent 'undo anything' tools that all dads get for fathers day.
The gear in them is too coarse so everything slips out.
PostPosted: Wed Jun 15, 2011 9:47 am
How about a crowsfoot wrench on a normal rachet handle?
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Wed Jun 15, 2011 9:55 am
Whenever i use these, my knuckles always end up second best! there dodgy and crap, most of the time they end up rounding the bolt or nut head
PostPosted: Wed Jun 15, 2011 11:09 am
This space for rent
I would have thought the reason for using a ratchet spanner was because space is at a premium.. a ratchet on that thing would never fit :lol:
 Post subject: invent
PostPosted: Wed Jun 15, 2011 2:08 pm
Warren and Brown have the better openended ratching spanners arround!
http://www.warrenandbrown.com.au/Includ ... Wrench.pdf
Not cheap though!
 Post subject: Re: invent
PostPosted: Wed Jun 15, 2011 4:40 pm
Not cheap though!
30 degrees ratchet is pretty average, and once youve got it in the tight spot 9 times out of 10 youll have put it in backwards. Im not a fan.
PostPosted: Wed Jun 15, 2011 5:56 pm
Not cheap though!
I have those exact wrenches, and they are useless.
Need too far to swing and that's if you can get a grip.
I may have used them once successfully.
Ratcheting ring spanners though are worth their weight in gold.
PostPosted: Wed Jun 15, 2011 7:45 pm
Favourite tool in the world!
You're so square
Baby I don't care
PostPosted: Wed Jun 15, 2011 9:54 pm
The straight ones are pretty useless in confined spaces, I've hardly used my Gearwrench ones.
