It is currently Sun Jul 27, 2025 9:20 am
Can the block be saved
yes 22%  22%  [ 6 ]
possibly 19%  19%  [ 5 ]
not a chance 33%  33%  [ 9 ]
asparagus 26%  26%  [ 7 ]
Total votes : 27
PostPosted: Thu Jun 16, 2011 11:08 am
Resident Haemorrhoid
its the #4 Cyl
on number 4 cyl :cry:
not sure if i can save this block as the pistons currently in it are A2/71 040
(40 thou overbored yeah?)
next question is what happened to cause this?
my guess that the gudgeon pin has moved is this a common fail?
Doc you on air???
BTW anyone got a 1098 block in good nic??
mtsmini wrote:
Tombo wrote:
PostPosted: Thu Jun 16, 2011 11:15 am
Could be saved with a massive overbore and rare pistons, or sleeving.
But it would be much more economical to get a new block. I have one here if you cant find one locally.
PostPosted: Thu Jun 16, 2011 11:23 am
As Kirby says, a big overbore or more probably resleeve it.
On a Cooper S block you might bother saving it, but anything else I would just grab another block off the pile and use that.
PostPosted: Thu Jun 16, 2011 11:33 am
This space for rent
Looks like a small bore by the spacing between 2 and 3.. I'd bin it and find another.
PostPosted: Thu Jun 16, 2011 11:48 am
If it's a small bore, find another, they're a dime a dozen, or free.
Big bore, i'd look into boring and sleeving costs, and weigh it up against a new big bore block
You're so square
Baby I don't care
PostPosted: Thu Jun 16, 2011 12:18 pm
Salvagable - yes by sleaving, but probably not worth it. Might need to make some phone calls.
Cause - usually from the last guy fitting the pistons to the Rods putting the circlips for the gudeon pins in the wrong way around and / or dirty assembly. I also use loctite on them.
Common - yeap, quite common.
Get some Ozzy 998 rods - they were a press fit pin and will directly interchange with the floating type.
PostPosted: Thu Jun 16, 2011 2:49 pm
So, cylinder #4...
There are plenty of 3cyl daihatsus around - a few mods and you can be up and running again!
PostPosted: Thu Jun 16, 2011 3:32 pm
Thats what mine will lokk like when pulled apart (or breaks) the circlip holding the gudgeon pin in is gone and the gudgeon pin runs up against the bore :shock:
PostPosted: Thu Jun 16, 2011 3:37 pm
its a 1098 block are all 1098's small bore??
if so i am guessing 1275's are considered big bore ?
or is there more to it??
mtsmini wrote:
Tombo wrote:
PostPosted: Thu Jun 16, 2011 3:40 pm
Thats right, 1098 small bore 1275 big bore
PostPosted: Thu Jun 16, 2011 3:47 pm
998 block = 1098 block, just different crank
Known as small bore
1275 block = Big Bore, lots more $$$, wizardry and more $$$
You're so square
Baby I don't care
PostPosted: Thu Jun 16, 2011 3:53 pm
Known as small bore
Piston height is different too- but rods are the same.
PostPosted: Thu Jun 16, 2011 4:02 pm
typical problem.. one of my 1100's did this years ago.. lasted 10yrs on the build until it did it..
As others have said, yes most likely fixable, but most likely not worth it for the price you can get another block.
I have a 1098 block here if you can't find one down there..
MinisPlus
I've had quite a few small bore motors re-sleaved. You don't need to do all the cylinders, and it wasn't that expensive either. It's not uncomon to find blocks that were sleaved from the factory..
How can it be rusty when it's covered in so much oil?
PostPosted: Thu Jun 16, 2011 4:32 pm
Known as small bore
Okay starting to feel like a bit of a noob
my block says 1098 so depending on the crank n pistons it could only be a 998 yes or does a 998 block have 998 on the side?
will the psitons have any special marking if they are for a 998 crank and will the same go for the crank will it have its own marking identifing what sort?
it has a 12G head on it they are they the better ones?
mtsmini wrote:
Tombo wrote:
