It is currently Sat Aug 16, 2025 5:22 am
PostPosted: Mon Jun 27, 2011 9:46 pm
Die Die Die!!
hi all, ive had a bit of an idling/tuning issue with my spi rover
over the last 2 weeks, my car has stalled 3 times.. (when hot and cold) while idling, if i push the accelerator to try and keep revs up and keep the car idling it doesnt rev like normal, it kind of maintains to a level but continually tries to die.
it continues to do this even when restarted untill i drive off.. then the car works like normal (even when stopped and idling)
any ideas ?
Thanks,
Nick
PostPosted: Mon Jun 27, 2011 10:29 pm
Sounds like you have a vacuum leak between the manifold and computer.
Mine was doing the exact same thing a few weeks ago, but it needed 5 minutes after it stalled to restart and that was a PITA.
PostPosted: Tue Jun 28, 2011 6:36 pm
Die Die Die!!
i will investigate, and get back to you..
PostPosted: Tue Jun 28, 2011 7:27 pm
Check the hoses at the back of the inlet manifold near the firewall.
2008 Prado GXL
PostPosted: Wed Jun 29, 2011 8:55 am
Check that whatever is blanking off your red vacuum line is still there, since it should be given you have a pod filter.
PostPosted: Wed Jun 29, 2011 12:36 pm
If I remember correctly I had a screw in the end of the hose (which was cable tied to the firewall), it may have fallen out or come lose with all the front end work you had done after the acco.
PostPosted: Wed Jun 29, 2011 1:10 pm
Rover Cooper
Doesn't Steve from Brickworx hang around here anymore, he was or should still be the GURU of SPI's. :roll: :roll: :roll: :roll: :roll: :roll:
PostPosted: Wed Jun 29, 2011 1:33 pm
Long gone from Ausmini.
It's a level playing field again.
PostPosted: Wed Jun 29, 2011 5:53 pm
Die Die Die!!
ill have a look on saturday for all these things..
and steves long gone davo111, now as far as i know your on your own as far as tuning the SPI's
PostPosted: Wed Jun 29, 2011 10:26 pm
The engines get a bit tempermental occasionly but are generally straight forward to sort out for issues, if you identify what it is.
There's a couple of people hiding in Vic with tuning computers if need be.
PostPosted: Thu Jun 30, 2011 8:11 pm
Hi,
check the vacuum hoses in particular the one going from the inlet to a fuel trap and then to the ECU. They tend to block causing bad idling/running.
Luis
Users browsing this forum: No registered users and 299 guests
