It is currently Tue Jul 22, 2025 1:09 am
PostPosted: Thu Jul 14, 2011 2:47 pm
So Im rebuilding my wiring loom and want suggestions of what to add even if Im not using it now.
I.e Im adding a power line for an electric fuel pump but only using a mechanical one ATM. Its and 850 loom so is already pretty bare.
Any suggestions?
PostPosted: Thu Jul 14, 2011 2:50 pm
Give Ash some flowers Nick .
I would add head light relays and possibly a relay for a thermo fan.
PostPosted: Thu Jul 14, 2011 3:21 pm
Adaptronic ECU :-)
PostPosted: Thu Jul 14, 2011 4:55 pm
+ for headlight relays
Front Fog OR Driving Lights cicuit with relay.
Reversing lights.
Better fuse box!!
Accesories circuit for radio and 12v socket to power phone chargers, GPS etc.
Also consider two speed wipers.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Thu Jul 14, 2011 7:39 pm
Additional to the above
Additional Gauges, Tacho, Vault ?
Thicker &/or additional wires if going Alternator
With the relay for the head lights & horn I also replaced the head lights wire with thicker gauge wires
PostPosted: Thu Jul 14, 2011 8:28 pm
Replace the blue, blue/white, blue red wires with auto spark quality 20 amp wire. You can do the lot, or just from the relays to the lights if you go that way. Your lights will glow much brighter for it, especially with a set of H4s.
Also do the same to the black wires coming from the lights back to the ground point in front of the fuses.
