It is currently Mon Aug 04, 2025 5:13 am
PostPosted: Mon Aug 22, 2011 11:15 pm
as it says... so far i have figured it's bigger than 32mm as thats the biggest socket in the tool box!!! lol
thanks
PostPosted: Mon Aug 22, 2011 11:26 pm
1 5/16" :) (about 33.3mm)
PostPosted: Tue Aug 23, 2011 8:42 am
Which is a good socket to have if you own a mini as it also fits disc brake hub nuts, steering wheel retainer nut, and varoius engine ones you'll probably never need.
PostPosted: Tue Aug 23, 2011 8:52 am
Check your hub nut size, before buying a 1-5/16" socket.
Recent ones are made from 34mm hex bar. If this includes yours I'd buy a 34mm socket instead. It will still fit your steering wheel, crank pulley bolt and camshaft nut. :wink:
PostPosted: Tue Aug 23, 2011 9:40 am
Does 15/16 whitworth ring a bell?? (my old mans shed is mostly whitworth 8) )
PostPosted: Tue Aug 23, 2011 10:09 am
Whitworth? You wash your mouth out........
:lol:
PostPosted: Tue Aug 23, 2011 10:49 am
Bloody hard to find in the local shops when i looked, most places stopped at 1 inch in Imperial measures.
PostPosted: Tue Aug 23, 2011 10:54 am
You can get the right sockets in real tool shops, or truck stores.
PostPosted: Tue Aug 23, 2011 12:47 pm
cheers guys think i will be buying a 34mm......
lol
Also on a bit of a side note, i'm doing this to get the steering rack out, how do you go at getting the crappy snap bolts off the column bracket!?
PostPosted: Tue Aug 23, 2011 12:55 pm
Vice grips .. i know it sounds a bit rough but it works ... Good Vice grips not cheap copys ...
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
PostPosted: Tue Aug 23, 2011 7:45 pm
:lol: don't forget to re-torque correctly with vice grips.
PostPosted: Tue Aug 23, 2011 10:39 pm
do you need to loosen off both top bolts..... To get the steering rack out?
On the Rover the passanger side bolt is a %@# to get at!!!!
PostPosted: Tue Aug 23, 2011 11:36 pm
...or weld a nut on... And don't forgett to wrap a pillow round your head when you pull the steering wheel off!! :lol: (don't ask me how I know... *smack!* :twisted: )
PostPosted: Wed Aug 24, 2011 12:14 am
Vice Grips? Christ thats rough.
PostPosted: Wed Aug 24, 2011 8:13 am
Beanie is talking about the conical `security nut' on the top column bolt, not the steering wheel nut.
I cut a flat on it first to give a grip.
I didn't bother fitting another funny nut, I used a real one. :wink:
