It is currently Sun Aug 03, 2025 1:38 pm
PostPosted: Tue Aug 30, 2011 8:13 pm
Looking to upgrade the wipers on the van, was looking at this set from minisport http://www.minisport.com.au/prod464.htm are they any good, wondering where other people have bought wiper sets from? Cheers :)
PostPosted: Tue Aug 30, 2011 8:55 pm
Hiya,
I bought these for mine. They look the goods!!! We had to grind a fair bit off of the chrome finishing bits (or whatever thay're called :oops: :lol: !) on the flat side to make them fit right, but i was told that when i bought them. And they fit perfect now!
Having said that...........me thinks my wiper motor might be a dud, so i havent been able to give the new shiny bits a go yet :cry: !
Cheers, Kim :-)
**purple '68 deluxe!**
***FINALLY wearing number plates----yeaaaaaah baby! ***
PostPosted: Wed Aug 31, 2011 2:05 pm
Can you still buy S/S Tex wiper arms and blades
PostPosted: Wed Aug 31, 2011 4:09 pm
Yes you can, from Minispares UK...
My Tex ones needed rubbers replaced, they are held in with no clips and I can't see how to replace them. :x The rubbers' ends are moulded.
So, I got some Chinese made plastic blades from Karcraft. Cheap as chips and work fine, but are not Bling.
PostPosted: Thu Sep 01, 2011 3:15 pm
I am looking at new ones too, but i am confused as to which ones will suit my car.. :?
The minisport AUS ones say they suit from 68- on
will these ones from minispares fit my 64??
http://www.minispares.com/Product.aspx? ... 248&title=
They say suit RHD MK1 that have RH park.
Thats right isn"t it???
Dusk Blue
1964 850
PostPosted: Thu Sep 01, 2011 3:19 pm
Those should be right for early cars that were RH park. Same wiper setup.
But their LH park ones don't suit later Oz cars 1968> unless you rebend the end of the arm. The UK spindles are in a different spot to ours.
PostPosted: Thu Sep 01, 2011 5:51 pm
Ok, so can you bend the arms easy enough or should I look somewhere else for wipers? my van is 71, so parks on left when your in the car
PostPosted: Thu Sep 01, 2011 6:13 pm
Something doesn't seem right with that first mentioned kit. The 68 onwards aussie cars had the wiper bases recessed into the scuttle panel: the chrome bit shown looks like an english / 850 one which is a different angle.
PostPosted: Thu Sep 01, 2011 8:29 pm
I don't really need the kit, just a good set of wiper arms and blades for 68> as mine are badly worn. Doc do I need to bend the tex wiper arms as well?
PostPosted: Thu Sep 01, 2011 10:54 pm
I had to bend my Tex arms (from UK) to fit my `70 Mini.
But once done, you can fit aussie blades on if you want.
[edit] by arm I mean the bit attached to the spindle.
Blade is the whole top bit, with the rubber in it.
PostPosted: Fri Sep 02, 2011 9:44 am
Thanks Doc :)
