It is currently Mon Jul 21, 2025 5:31 pm
 Post subject: After market fuel pumps
PostPosted: Thu Sep 22, 2011 10:12 am
Die Die Die!!
The fuel pump on my mini has jus died, has anyone had to replace the fuel pump for an SPI rover before ?
I see walbro do one (item ITP044) and also I've heard of people using a walbro 516 ?
Is there anything else ? As $500 for a genuine replacement Isnt an option due to price
PostPosted: Thu Sep 22, 2011 11:12 am
I've changed the fuel pump in mine before, its a fiddly job but straight forward.
I just replaced it with another used rover one cause it was the most straight forward and cheapest option.
If you find anything else that works / fits I'd be interested to see how you go as may be of use to me one day.
PostPosted: Thu Sep 22, 2011 11:54 am
I went to Upull it ( or any wrecker ) found the fuel pump out of a nissan Micra and adapted it to suit the mini .. it isnt an easy job but it does mean that any in tank pump can be modified to fit ..
had to make sure the pick up was in the right place and low enough ...
Beanie
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
PostPosted: Thu Sep 22, 2011 12:14 pm
Any dimensions/photos of the original one? I've never seen a original rover one, but i'd think there would be a fair chance a universal 38mm or 51mm intank pump could be made to fit. I've fitted a few of these to replace odd/expensive oem pumps with good success. Usually sell for $50-$75 new.
Andrew
PostPosted: Thu Sep 22, 2011 12:44 pm
I've got a spare pump assembly less the motor, you're welcome to find something else that'll fit. :lol:
PostPosted: Thu Sep 22, 2011 12:45 pm
Die Die Die!!
Minispares have a photo of the original, ideally I'm after a bolt on a/m pump as I don't have the facilities to be modifying things,
ATM I'm thinking I'll have to import one
PostPosted: Thu Sep 22, 2011 1:09 pm
i would rather adapt one to suit ...
The SPi ones on minispares are 115 pound ... and the genuine rover ones are pus if you ever want to do more to your car ( honda / starlet/turbo)
i dont know if its possible but why couldnt you put a VL commodore one under the car ... leave the other one in there
Beanie
HOTBRICKS
'65 NCF MINI.....
PostPosted: Thu Sep 22, 2011 2:10 pm
Die Die Die!!
I think I'll get the walbro apparently it's easy to install
[QUOTE=Kam;247229]Yeah the fitting kit comes with the pump with all you need, all it comprises of is a wiring plug, pump filter, few clips and a small pipe. Its a generic fitting kit for the walbro in-tank pumpsĀ
All you need to do is splice in the new wiring plug, the new pump attaches just like it did before but you might need a cable tie to hold it a bit firmer to the pipe running alongside it, it'll make sense when you put it together, nothing difficult, I did it :lol:[/QUOTE]
PostPosted: Thu Sep 22, 2011 2:17 pm
The Walbro 516 is about 5 times the pressure of the factory pump, so stick with the other ITP044 I think.
:D
PostPosted: Thu Sep 22, 2011 2:28 pm
Die Die Die!!
I'm going the walbro GSS342,
And that is true but apparently the computer controls the pressure
PostPosted: Thu Sep 22, 2011 2:41 pm
The computer doesnt control the pressure or even the flow, it just turns the pump on / off, though there is a regulator in the throttle body housing.
I'm just thinking if you're going to upgrade to a higher pressure pump, then you should upgrade all the hose clips too. I don't even run factory clips on a standard car, no way do I want any fuel leaks!
PostPosted: Thu Sep 22, 2011 3:42 pm
Die Die Die!!
Yeah that's true.. I'll have to get a packet of hose clamps too..
PostPosted: Fri Sep 23, 2011 8:27 pm
Die Die Die!!
well i had it all in my hands.. turns out the origonal wasnt broken after all.. DOH !
and the walbro GSS342 definately doesnt swap straight over.. the walbro has a male fitting and the pump pipes a male too so you would need to join the 2 by using a little hose and some hose clamps or something of the sorts, i didnt take it any further as i found my worked.. so good luck to anyone going this path !
PostPosted: Fri Sep 23, 2011 9:30 pm
So push the pump reset button on your dash and get back to driving then! :lol:
PostPosted: Sat Sep 24, 2011 12:51 am
Die Die Die!!
turned out it was just a faulty wire from the ignition to the fuse box..
not before i pulled the whole damn lot out thought ... always the way
