It is currently Wed Jul 23, 2025 2:36 am
PostPosted: Wed Oct 19, 2011 11:04 am
Hi all,
I am changing over to a Weber carburettor for my 1275, just to give it a go over the HS6 I have on it currently.
I will be buying new - and the guys I am buying off say they can jet it to suit when I buy it.
So I ask you all: what is a good base tune for my engine?
It's a large journal 1275, standard head (A+), 123 distributor. Everything is standard apart from that.
Any help greatly appreciated.
As for manifold, it will either get a swan neck, or a 3 inch style.
Cheers.
Tyson.
PostPosted: Wed Oct 19, 2011 11:19 am
i`d suggest the redline/warnford 3&1/2 inch manifold
& just as a starting base-->
idle jets-50F9
pump jets 50
block off the pump by-pass jet (inside the bottom of the float bowl)
aux ventures 3.5
chokes 34
emulsion tubes F11
mains 145
air correctors 180
PostPosted: Thu Oct 20, 2011 8:09 am
idle jets-50F9
pump jets 50
aux ventures 3.5
chokes 34
emulsion tubes F11
mains 145
air correctors 180
Yeah sounds good here too ...
Except I use 4.5 aux ventures
Matt you say block off the pump bypass Jett , how do you do this and why
Beanie
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
PostPosted: Thu Oct 20, 2011 8:18 am
Beanie,
The reason this is done is to get more fuel per pump stroke by shutting the bleedback to the bowl. This is needed on a siamese port engine because you have 2 cylinders sucking on each port, not 1 as with an Alfa for example.
With a Dellorto 45 you achieve the same result by increasing the pump stroke (adjust actuating rod locknuts).
