It is currently Sat Jul 19, 2025 4:20 am
PostPosted: Tue Nov 08, 2011 2:34 pm
Hey all,
Powdercoating, which parts other than the subframes would you get powdercoated?
AJ
1978 Leyland Clubman S
PostPosted: Tue Nov 08, 2011 2:50 pm
Radiator shroud
PostPosted: Tue Nov 08, 2011 3:01 pm
Seat frames
Engine steady bars
Top rad bracket
Um... that's all I can think of at this minute
PostPosted: Tue Nov 08, 2011 5:35 pm
You are better to paint subframes Power Coating chips and rusts under neath
2k paint is best for subframes
PostPosted: Tue Nov 08, 2011 6:38 pm
I had my seat brackets and pedal bracket and pedals powder coated
Subframes were 2k'ed by the sand blaster
I also had some wheels powder coated, these are planned to be used as spares for each of the fleet
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue Nov 08, 2011 6:46 pm
I agree, powdercoat adhesion is pretty poor unless you grit blast the subbys.
The other prob with powdercoat is most stuff done has piss poor UV resistance. It fades like buggery in sunlight.
PostPosted: Tue Nov 08, 2011 7:54 pm
If you look around , a lot things are powdercoated, clothes lines come to mind,
and after few years it come off in sheets.
I'd be interested to hear from any who have had powdercoating done on car parts and how it has stood up.
PostPosted: Tue Nov 08, 2011 8:29 pm
I had the sunraysia wheels done on my Moke about seven or eight years ago and it hasn't stood up that well, it has developed cracks on the spoke part and has oxidised a bit. About a year later I had the roll bar and bumpers done by a different bloke. They still look as good as they day they were done, even on the top surface where they cop the most sun. There are many different types of powdercoat and clearly some are a lot better than others.
The guy that did the wheels specialised in metal furniture and the guy that did the bars specialised in fence panels.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Wed Nov 09, 2011 11:05 am
The subframes would be sand blasted then powdercoated.
PostPosted: Wed Nov 09, 2011 5:06 pm
Judging by the responses, powdercoating isn't the way forward...
Might just get all the above stuff sandblasted and then get some POR15? Or is 2K better?
PostPosted: Wed Nov 09, 2011 6:07 pm
POR15 is way tougher stuff than 2K. Excellent for subframes etc. As long as you want black, grey or white! :lol:
PostPosted: Wed Nov 09, 2011 6:27 pm
I got my Firsat's powdercoated Hammertone Grey , what I like most is that they change color with the light , no chips or scratches yet after two + years
PostPosted: Wed Nov 09, 2011 7:41 pm
i
I POR15 my subframe and wasn't that impressed with it.
Horrible stuff to work with had a wicked headache for days even with a mask on.
They say brake fluid will not effect it, don't agree mine bubbled up after a minor spill which was cleaned with water straight away
Its hard to touch up if you get a scrape
I sent my subframes off on Monday to be sandblasted and 2k prior and painted gloss black
I also found that my subframe was rusting under th POR15, I chiped some off to see how hard it would be to strip back to bare frame again and it was a brown rusty colour.
I am not sure if the fire the car was in had anything to do with that but the part I chipped off was not damaged and still very shiney
And its exspensive
Kiwiinwgtn
PostPosted: Wed Nov 09, 2011 8:45 pm
If you powder coat parts don't forget to tape up any threads. I had to clean out the threads on my pedal box and take the chroming off the bonnet catch too. Not a fun job.
Users browsing this forum: Bing [Bot] and 81 guests
