It is currently Sat Jul 19, 2025 2:54 am
 Post subject: tyre pressure query.
PostPosted: Mon Nov 07, 2011 7:23 pm
hey,
i currently have Yokohama A048R's - 165/55 R12. i was wondering if there was a optimal tyre pressure to run in the rear tyres. Currently i have 19 PSI in the rear and they still seem quite firm. There is no weight over the back, i don't take people in the rear seat, i don't carry a spare tyre/jack around town, i have a small light weight battery. Is is absurd to run any lower?
Thanks,
Bill
PostPosted: Mon Nov 07, 2011 7:26 pm
Not sure about 12" wheels but I run 28psi at the front and 26psi at the back, slightly more if going for a high speed freeway run. 19 sounds way too low to me...
PostPosted: Mon Nov 07, 2011 7:30 pm
well take a look at this, these are both at 19 PSI, they don't even pillow at the bottom!? Magic.
Bill
PostPosted: Mon Nov 07, 2011 8:35 pm
32 psi front and 28 psi back is what I recommend , two recommended factory pressures for 3.5x10 and 4.5x10 were 26 front 24 rear and 28 front and 26 rear , I tried on my Mini S the latter but have moved up to 32 front and 28 back and I,m not going to change anytime soon
PostPosted: Mon Nov 07, 2011 9:54 pm
Just cause they look right don't make them right. It's because they have strong sidewalls to prevent rolling over in heavy cornering. I suggest you pump them to at least 25psi
PostPosted: Mon Nov 07, 2011 10:25 pm
I've always run 32/30 in all my minis
My mechanic runs the same on all of his mini's too!
You're so square
Baby I don't care
PostPosted: Mon Nov 07, 2011 10:37 pm
I am also a 32/30 guy.
32/32 if I am feeling lazy :lol:
PostPosted: Tue Nov 08, 2011 7:15 am
32/32 if I am feeling racy :lol:
Fixt
You're so square
Baby I don't care
PostPosted: Tue Nov 08, 2011 7:36 am
I run 30/28 around town but that's with 10s. Works for me... :wink:
PostPosted: Tue Nov 08, 2011 7:41 am
I always put that little bit extra, because I know it will have leaked out by the next day anyway ;)
You're so square
Baby I don't care
PostPosted: Tue Nov 08, 2011 12:24 pm
fine, i'll increase the pressure......... :?
PostPosted: Tue Nov 08, 2011 2:02 pm
Well it's up to you hoenstly, it's your car, your tyres and quite possibly your life if you do a corner too quickly and the sidewall collapses resulting in disaster.
All I know is, there is a BIG handling difference between 25psi and 32psi in my car so I'd hate to think what it would handle like on 19psi...
PostPosted: Tue Nov 08, 2011 2:05 pm
When I first bought my car, I drove it home from sutherland to blacktown on 8psi
I thought it was just the no power steering..
You're so square
Baby I don't care
PostPosted: Tue Nov 08, 2011 6:03 pm
Yep , same as Adam & Doc , 32/30 psi .
