It is currently Sat Aug 09, 2025 4:42 am
PostPosted: Tue Nov 15, 2011 7:59 pm
I am getting a temporary engine to keep my van on the road.The one im getting has the remote shifter.My van has magic wand which i want to keep so is changing a remote shifter as simple as unbolting a few parts and replacing with bits from my wand.
PostPosted: Tue Nov 15, 2011 8:28 pm
`Difficulty' depends what year your van is.
There are 2 so called `magic wand' setups- the original used on 850s etc up to `69 (3 synchro boxes), and the `puddin' stirrer' used on vans and pov pack cars from 1969-1774 approx (4 synchro remote box + gearshift attachment).
If yours is the later sort, the swap from remote to your puddin' stirrer is just a matter of swapping shifter bits from yours onto the remote diff housing.
If yours is earlier type however, it involves swapping the diff housings- this is not entirely straightforward as the diff bearing bores have to be checked for size and roundness when magic wand diff housing is attached.
[edit] here's the puddin stirrer type, as you can see the diff housing is a `remote' one.
PostPosted: Wed Nov 16, 2011 10:14 am
This may solve a similar problem for me too, does both a wand and stirrer come thru the floor in exactly the same spot?
'63 850/1100 + more cooper goodies
PostPosted: Wed Nov 16, 2011 10:46 am
Yes I think they do.
Be aware that the puddin' stirrer bits are a bit hard to find these days.
Last edited by drmini in aust on Wed Nov 16, 2011 10:52 am, edited 1 time in total.
PostPosted: Wed Nov 16, 2011 10:50 am
I've got some (at least I knew where they were before I moved) if you are desperate I can look them out
PostPosted: Wed Nov 16, 2011 8:50 pm
Sweet i have a puddin stirrer 8)
Thanks again doc.
PostPosted: Wed Nov 16, 2011 9:41 pm
I got NOS puddin' bits from John Schmidt at Mini King
You're so square
Baby I don't care
PostPosted: Wed Nov 16, 2011 10:07 pm
And I guess a rod change would be as hard to convert to stirrer like a wand is?
PostPosted: Wed Nov 16, 2011 10:13 pm
harder, as in that one can`t actually be done
edit, unless you change the whole box over :-)
PostPosted: Wed Nov 16, 2011 10:19 pm
Good thing I wasn't planning on going that direction haha
As long as i can have a stirrer mated to a remote casing and it comes thru the wand hole, im as happy as a pig-in. That I can work with :)
PostPosted: Wed Nov 16, 2011 10:22 pm
You can shorten the rods on a rod change. That's how they fitted them into Mokes without moving the gearstick hole.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
