It is currently Sat Aug 09, 2025 4:57 am
PostPosted: Tue Nov 15, 2011 7:59 pm
I am getting a temporary engine to keep my van on the road.The one im getting has the remote shifter.My van has magic wand which i want to keep so is changing a remote shifter as simple as unbolting a few parts and replacing with bits from my wand.
PostPosted: Tue Nov 15, 2011 8:28 pm
`Difficulty' depends what year your van is.
There are 2 so called `magic wand' setups- the original used on 850s etc up to `69 (3 synchro boxes), and the `puddin' stirrer' used on vans and pov pack cars from 1969-1774 approx (4 synchro remote box + gearshift attachment).
If yours is the later sort, the swap from remote to your puddin' stirrer is just a matter of swapping shifter bits from yours onto the remote diff housing.
If yours is earlier type however, it involves swapping the diff housings- this is not entirely straightforward as the diff bearing bores have to be checked for size and roundness when magic wand diff housing is attached.
[edit] here's the puddin stirrer type, as you can see the diff housing is a `remote' one.
PostPosted: Wed Nov 16, 2011 10:14 am
This may solve a similar problem for me too, does both a wand and stirrer come thru the floor in exactly the same spot?
'63 850/1100 + more cooper goodies
PostPosted: Wed Nov 16, 2011 10:46 am
Yes I think they do.
Be aware that the puddin' stirrer bits are a bit hard to find these days.
Last edited by drmini in aust on Wed Nov 16, 2011 10:52 am, edited 1 time in total.
PostPosted: Wed Nov 16, 2011 10:50 am
I've got some (at least I knew where they were before I moved) if you are desperate I can look them out
David L
PostPosted: Wed Nov 16, 2011 8:50 pm
Sweet i have a puddin stirrer 8)
Thanks again doc.
PostPosted: Wed Nov 16, 2011 9:41 pm
I got NOS puddin' bits from John Schmidt at Mini King
You're so square
Baby I don't care
PostPosted: Wed Nov 16, 2011 10:07 pm
And I guess a rod change would be as hard to convert to stirrer like a wand is?
PostPosted: Wed Nov 16, 2011 10:13 pm
harder, as in that one can`t actually be done
edit, unless you change the whole box over :-)
PostPosted: Wed Nov 16, 2011 10:19 pm
Good thing I wasn't planning on going that direction haha
As long as i can have a stirrer mated to a remote casing and it comes thru the wand hole, im as happy as a pig-in. That I can work with :)
PostPosted: Wed Nov 16, 2011 10:22 pm
You can shorten the rods on a rod change. That's how they fitted them into Mokes without moving the gearstick hole.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
Users browsing this forum: No registered users and 72 guests
