It is currently Sun Aug 03, 2025 5:01 pm
 Post subject: clubman dash mystery
PostPosted: Tue Nov 29, 2011 2:29 pm
after no luck searching the forums i am after some help
does any one know what each warning light is on a 3 gauge dash
speedo: Red = Amp?
fuel/temp: Orange = oil?
fuel/temp: red = ?
fuel/temp: blue = highbeam
tacho: purple =?
and is there diferent types of binical surround other than mph/kph
different fonts or colors on the rover or gt?
id love to know what the unused bulb holes were intended for and why they never got used in australia or uk
1969 Blue Mini K, 1330cc, Weber 45, polished aluminum roll cage, Race seats, 4 point harness, full rewire incorporating 8 fuses, 6 relays and new headlights :) just needs tyres front shocks and a windscreen til re-register
PostPosted: Tue Nov 29, 2011 3:04 pm
On my dash the centre 2 are the blinkers and the right one I think is the airbag warning.
I assume you mean the UK dash?
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue Nov 29, 2011 4:02 pm
clubman
centre clock (fuel and temp guage clock)
orange light on the lower right is oil and the red on lower left is amp/charge.
Blue light on speedo is high beam.
I dont know what the tacho light at the bottom is?
fuel/temp= lower right orange: Oil
fuel/temp= lower left red: Amp/charge
Speedo= centre: blue
Tacho= ?? no idea never seen it come on/ dont even know colour
I should probably pay more attention next time im driving my GT as to what lights there are dont ever come on and what colour they are.
But i know the above are correct
Brenton
PostPosted: Tue Nov 29, 2011 6:06 pm
ive puled the instrument cluster apart and the purple light is there but no copper film stuff or wires go to it just an empty globe spot
PostPosted: Tue Nov 29, 2011 8:11 pm
I think there is another light on the speedo, maybe a red one as you say.
Ive never seen it come on either, so have no idea what its for either
 Post subject: Re: clubman dash mystery
PostPosted: Tue Nov 29, 2011 11:20 pm
speedo: Red = Amp?
fuel/temp: red = ?
tacho: purple =?
I think they just added a couple of extra spots (on the speedo & Tacho) when designing them in case they were ever needed. (The early Cooper S speedo has an extra light that was never used for anything also.)
Early 70's 3 gauge sets had MPH and KPH I think as this was around the time Australia was going metric. That set of guages was used in other cars too eg Morris Marina.
As Brenton could explain the genuine Aussie GT gauges had speedo with a higher top speed and the rev counter had a higher red line.
PostPosted: Wed Nov 30, 2011 8:50 am
Hey Phil, your right.
The extra lights in the dash in a clubman are just spares, they dont work and and i have been told they are not even accomodated in the circuitry. (if i looked at mine i would find this is the case)
Phil about the GT cluster having higher speed and tacho redline, thats correct.
But the 3 clock clusters are the same design from 71-78. So why i used mine to explain :wink:
