It is currently Wed Aug 13, 2025 5:57 pm
 Post subject: piston diameter?
PostPosted: Tue Jan 03, 2012 2:32 pm
What is the STD diameter of a 1275cc piston?
and what is the diameter of a 0.080 thou over bore piston (1360)?
PostPosted: Tue Jan 03, 2012 2:41 pm
70.6mm is std 1275 bore size.
73.0mm is +.094" (1360cc) bore size.
Piston to bore clearance is around .0015"-.0035", depending whether they are cast or forged.
PostPosted: Tue Jan 03, 2012 2:48 pm
so 72.16mm is good enough so long as the block gets bored to suit?
Is that still 1360cc?
PostPosted: Tue Jan 03, 2012 2:54 pm
Nope that is +.060", = 1330cc. Still pretty good... 8)
Next size up from that is 72.5mm (GR pistons) = 1343cc.
Why overbore it heaps if no need, it's only worth pub points... :P
PostPosted: Tue Jan 03, 2012 3:16 pm
Coming from the guy with 1380's and 1412's :lol:
PostPosted: Tue Jan 03, 2012 3:32 pm
Hello... both mine are 1360 bore (73mm), so there is another 1 or 2 rebores left in both.
And I have a pile of std bore blocks too, so meh. :P
Users browsing this forum: slacko and 250 guests
