It is currently Sat Aug 23, 2025 7:26 am
 Post subject: oil pump woes
PostPosted: Wed Jan 04, 2012 5:38 pm
Resident Haemorrhoid
okay is it possible to install it upside down?????
I didnt fit it but when i pulled the flywheel housing off all the vaso i pumped into it trying to prime it was all around the outside of the pump.
I havent had a close look yet but i was wondering if it may of been installed upside down and been the cause for me not getting Oil Pressure.
ideas ????
Doc?????
mtsmini wrote:
Tombo wrote:
PostPosted: Wed Jan 04, 2012 5:52 pm
sounds like it isn`t tight...
maybe the bolts are too long?
maybe it`s cracked?
maybe it`s the wrong one?
etc?
what size engine? (as in what pump is it? 3-bolt pin/spade drive or 2 bolt spider/ spade drive?)
PostPosted: Wed Jan 04, 2012 5:56 pm
its for a 1098 and a 3 bolt spade drive i think i will have to compare it to the old one.
If ist cause ist to loose i will be exstatic or even the wrong one
i will have an investigate after dinner :wink:
mtsmini wrote:
Tombo wrote:
PostPosted: Wed Jan 04, 2012 6:32 pm
If it's a 3 bolt `pin drive' pump (std 998/1098), it will only fit one way.
There is a drain slot in the edge, this goes to the bottom.
Maybe the bolts are too long- aftermarket pumps vary in thickness a bit and it's one thing that should be checked these days before assembly.
Also check the threads are not full of Loctite or silastic from a previous engine build.
PostPosted: Wed Jan 04, 2012 7:19 pm
looks like the bolts holding the bugger in were a bees dick to long :evil: :evil: :evil: :evil:
but on the up side i wont have to separate the gearbox from the block :) :)
mtsmini wrote:
Tombo wrote:
PostPosted: Wed Jan 04, 2012 8:00 pm
i`m so awesome when i`m right :-)
PostPosted: Wed Jan 04, 2012 8:11 pm
8) 8)
mtsmini wrote:
Tombo wrote:
PostPosted: Wed Jan 04, 2012 8:16 pm
8) 8)
mtsmini wrote:
Tombo wrote:
PostPosted: Sat Jan 07, 2012 1:09 pm
woo hoo got oil pressure
:D :D
but on the down side thought i would fix the radiator cowling and put a hole in the radiator BUGGER
mtsmini wrote:
Tombo wrote:
PostPosted: Sat Jan 07, 2012 6:20 pm
You didn't try to attach the cowling with a self tapping screw, did you? The previous owner of my car did that.
PostPosted: Sat Jan 07, 2012 6:56 pm
yep :( :( :( :(
mtsmini wrote:
Tombo wrote:
PostPosted: Sat Jan 07, 2012 7:02 pm
Gadgets mini wrote:
yep :( :( :( :(
Yeah you need the right sort of (short) screws.
Many people bought Chinese alloy rads, and some of `em do come in without their short 6mm screws. So the owners bought some that were too long... oops, water leaks! :cry:
PostPosted: Sun Jan 08, 2012 10:06 am
If you can't get the right screws for the shroud you can at a pinch grind the point off very short self tappers.
PostPosted: Sun Jan 08, 2012 11:43 am
Hi there buddy and compliments of the season :)
This thing about the bolts being too long in your new oil pump, I bought up in that huge thread about engine rebuild (in the How To section) and the only reason I knew this was from a previous experience about 5 or so years ago.
However, I'm glad you sorted it and now have pressure :)
Rod Image
PostPosted: Sun Jan 08, 2012 5:44 pm
re the oilz pump-
Back in the 60s and 70s when these engines were built there were a few OEM pump suppliers, and not all pumps were the same thickness as those we get now.
Users browsing this forum: bharp831 and 299 guests
