It is currently Tue Jul 22, 2025 7:32 pm
PostPosted: Sat Jan 28, 2012 10:33 am
Hi folks,
Been working on the brick over the holiday period, just have a minor question. Has anybody replace their heater tap on the heater?. If so what did they use?, I trying to stay original as possible,....., would this item be compatible? as far as I can see it would require the lever mechanism to be re orientated? All thoughts gratefully received. At the moment I have plumbed both hoses direct to the core.
http://www.rarespares.net.au/rarespares ... uct=HT2001
Cheers Pete.
December 1976 Leyland Mini S aka 'The Brick'
2012 Toyota Prado GX aka 'The Truck'
"Where The Hell is ARDLETHAN!!" :-)
PostPosted: Sat Jan 28, 2012 11:19 am
As far as i know they are the same. Morris 1100 will know for sure.
but im like 95%certain they are
PostPosted: Sat Jan 28, 2012 11:34 am
Yeap, that is them.
PostPosted: Sat Jan 28, 2012 12:33 pm
I used one of these this week
Overnight delivery from rare sPares was very good service
Yes I used the old tap as a guide and changed the orientation of the cable connection
I also needed to use the metal guide from the old tap as the dimble was the wrong way around
But once you sit both taps side by side you will work it out
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sat Jan 28, 2012 5:38 pm
I just had a look at a few falcon spares websites that my mate gave me, turn out the rare spares one is the cheapest
PostPosted: Sun Jan 29, 2012 7:18 am
Or try this
http://www.ausmini.com/forums/viewtopic.php?t=44289
PostPosted: Tue Jan 31, 2012 5:01 pm
Hi Folks,
Thanks for all your replies. I now can order the part with a bit more confidence. Once again thanks everybody.
Cheers Pete
PostPosted: Wed Feb 01, 2012 5:31 pm
Hi Folks,
Now the tap question is sorted. I have another question that relates to the Heater...., The pedal box ducting that runs from the RH side to the Heater. Where to get some? :? Alternatives to the original waxpaper/Alum/waxpaper? :)
Cheers Pete
PostPosted: Fri Jun 15, 2012 9:29 pm
website called purple pig has all your piping needs!
Rich
PostPosted: Fri Jun 15, 2012 10:30 pm
http://www.purplepig.com.au/www/content ... 75&fid=782
Their product is good and their service fast.
I bought 1/2 a metre to do my `matic heater + a spare bit.
PostPosted: Sat Jun 16, 2012 10:19 am
how much was that pipe Kev? if ya don't mind me asking
I'm after some of the hose for the Mini-Matic heater to the firewall too
is it the one around 100mm in diameter?
PostPosted: Sat Jun 16, 2012 10:30 am
It was 83mm, black, I think cost was $30 for 0.5M long, including freight (they posted it from Rocklea branch, in Qld).
