It is currently Sun Jul 27, 2025 8:04 am
PostPosted: Wed May 25, 2005 1:10 pm
Is the 940 head on a small bore block worth it?
In bang for buck terms.
Other than the block pocketing, is there anything else that needs to be cut/shaved/waxed :shock: to get the head to fit. I vaguely recall hearing something about waterways needing re-alignment.
What's it cost in the end, head plus butchery.
My new signature got me thinking...
Morris 850 with 998 engine with 1098 internals..... may aswell finish "the mongrel" off with a 1275 head :)
PostPosted: Wed May 25, 2005 1:27 pm
Resident Haemorrhoid
Cushy
when I read the subject line I thought you may of been talking about an ausmini member or perhaps yourself. :wink: :wink:
the mods you are talking about i'd love to see a pictures in progress thread later :)
Gadget
mtsmini wrote:
Tombo wrote:
PostPosted: Wed May 25, 2005 2:17 pm
Nah won't fit - I'll do you a swap for a 202 :wink:
PostPosted: Wed May 25, 2005 2:18 pm
you can swap all you like... i don't have a 940 head... ;)
PostPosted: Wed May 25, 2005 2:22 pm
Bugger - was worth a try! :lol:
PostPosted: Wed May 25, 2005 2:23 pm
dont' you have a 1275 anyway?
PostPosted: Wed May 25, 2005 2:27 pm
Well I hve one 1275 but there's always room for more 8)
PostPosted: Wed May 25, 2005 2:35 pm
just in case people forgot :)
Other than the block pocketing, is there anything else that needs to be cut/shaved/waxed Shocked to get the head to fit. I vaguely recall hearing something about waterways needing re-alignment.
PostPosted: Wed May 25, 2005 2:40 pm
also... if i got the 1275 head, do i need to get 1275 LCB's to go with it...
PostPosted: Wed May 25, 2005 8:00 pm
940 head on a pocketed block... Do it. :P
Back in the 60s BMC UK offered it as a go-faster kit for 850 and 998.. :shock:
I had one years ago on a 1098 bored to 1220cc, in a light 850. Works 544 cam, twin Amal Monobloc carbs- then twin HS4s, it was revved (too often) past 8500 and did low 16s at Castlereagh dragstrip.
It was fun, while it lasted. At 20,000 miles, a circlip broke, gudgeon pin scored the bore, new crank had 8 cracks already. Oh well... I then got a 1275, but it didn't go as hard. :lol:
 Post subject: pocketed block
PostPosted: Wed May 25, 2005 8:56 pm
yeah i agree with the dr,i had a 998 with a full 12g940 race head and scatter pattern race cam on it years ago and it rev'd harder than my 1380 motor which was a similar spec.i think on dyno it made 54 kw at the wheels which is unreal for a 998
only thing extra than pocketing block is possibly filing down the water pump alloy housing on its topside as they sometimes wont let the head seal down properly(after 2 blown headgaskets found this out)
might do another of these engines as i have a 997 cooper motor with pockets in it already with a 998 crank and centre main strap mmmmmmmmmm
PostPosted: Thu May 26, 2005 9:46 am
DO EET
right.... so the next steps are ..
What does it take to get the block pocketed? casho , etc..
is there any other work other than the pocketing needed?
How much is a stock 940 these days? and who's got one?
and , again :), i use the 1275 head gasket and lcb exhaust?
would my 1.5" su be ok?
 Post subject: casho needed
PostPosted: Thu May 26, 2005 11:24 am
yes cash is the needed thing to do this
no other work is needed(just check water pump clearance)
stock 940 heads are plentiful i have a few of them for $180 each complete with valves and springs inn s/hand condition
1.5 inch carby is ok but if you want more power chuck on a 1 3/4 ($120 for a hif series :ie float bowl built onto bottom of carb )or a weber big $$$$
regards josh
PostPosted: Thu May 26, 2005 11:52 am
noice.... yaw just the boize noize, miniimpawts..
PostPosted: Thu May 26, 2005 7:42 pm
I have heard that a stock 940 head outflows a worked 295 head, so there, for wot it's worth. :wink:
BTW you don't need dirty big valves for this on a 998/1098, stocko 1100S or 1275LS (or stock Metro) ones are fine.
Fit decent double valve springs and a cam though. :lol:
Users browsing this forum: Bing [Bot] and 91 guests
