It is currently Sat Jul 19, 2025 5:33 am
 Post subject: fuel tank photo
PostPosted: Sun Feb 26, 2012 5:04 pm
ok guys has anyone have a photo of a left hand feul tank ,from around 1962 i believe there is a piece missing from mine i have a brass threaded hole in the bottom and i am thinling maybe it should have something attached at the moment it has a bolt in it help
not sure if someone has made the hole and drilled the thread for the bolt
PostPosted: Sun Feb 26, 2012 5:27 pm
I think you are talking about the drain plug?
It is a bolt with a tube out of the centre
You could also use a bolt if you have lost the original
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sun Feb 26, 2012 7:18 pm
DO NOT use a bolt - it won't seal properly
it's one of these, or use a brake bleeder
http://www.minisport.com.au/prod2131.htm
PostPosted: Sun Feb 26, 2012 7:40 pm
That's a good idea, never thought about a brake bleed valve :?
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Sun Feb 26, 2012 9:17 pm
Thread is 3/8 UNF.
These drains are a PITA, if/when my tank comes out again it'll be getting a brass plug and some Loctite. 8)
PostPosted: Mon Feb 27, 2012 8:16 pm
My vans tank has a bolt, similar to a sump plug. my sedans have the drain tube. What should the van have?
PostPosted: Mon Feb 27, 2012 9:26 pm
bolt - very different setup to a sedan
PostPosted: Wed Feb 29, 2012 8:46 pm
ok guys thank you very much for youre reply to my q's on fuel tank very much appreciated thanks for the link to the fuel pipe and for the ideas for the other methods.....laz
