It is currently Mon Aug 04, 2025 8:27 pm
 Post subject: speedo question
PostPosted: Fri Apr 06, 2012 4:32 pm
Hi all!
the speedo in my mini has not worked at all since I bought it 2 years ago.
This hasnt been much of a problem (i could judge 60kph from the tacho), untill I got a speeding fine the other week :(. I wasnt sure how many revs i was supposed to be doing to be going 50 haha.
everything else (fuel gauge, HB light and night time light) works on it however. Is it just a case of replacing the speedo cable to get it working again?
PostPosted: Fri Apr 06, 2012 4:52 pm
OK, remove the speedo, and take it for a drive, if you see the center moving, that means your speedo is stuffed. if its not, it could be the cable stuffed, or the pinion in the gearbox is stuffed
Users browsing this forum: Bill B and 106 guests
