It is currently Mon Aug 04, 2025 11:30 pm
 Post subject: speedo question
PostPosted: Fri Apr 06, 2012 4:32 pm
Hi all!
the speedo in my mini has not worked at all since I bought it 2 years ago.
This hasnt been much of a problem (i could judge 60kph from the tacho), untill I got a speeding fine the other week :(. I wasnt sure how many revs i was supposed to be doing to be going 50 haha.
everything else (fuel gauge, HB light and night time light) works on it however. Is it just a case of replacing the speedo cable to get it working again?
PostPosted: Fri Apr 06, 2012 4:52 pm
OK, remove the speedo, and take it for a drive, if you see the center moving, that means your speedo is stuffed. if its not, it could be the cable stuffed, or the pinion in the gearbox is stuffed
