It is currently Sun Jul 27, 2025 4:05 pm
 Post subject: Boiling battery???
PostPosted: Sat May 28, 2005 3:58 pm
While testing my new non leaking fuel cap - I noticed a lovely rotten egg gas smell. Check the battery, and sure enough the acid is merrily boiling away indicating over charging. (Can't find my multimeter to double check)
Now I've recently put what I thought was a reco alternator on my late model clubby (ie the bearings weren't suffed!) Am I correct in assuming all the regulation is done on the alternator itself - and I can swap bits over from a worn out bearing but otherwise functioning alternator?
Any tips here would be appreciated...
PostPosted: Sat May 28, 2005 4:39 pm
It would be easier to added new bearings :cry: I have pulled the regulator and diodes off an alternator but draw plenty of diagrams and label the wires and you will need a hefty soldering iron as with all the metal around the heat gets pulled away pretty quick and takes a while to get the solder hot
PostPosted: Sat May 28, 2005 8:23 pm
Busted regulator, last one I bought cost me 25 dollars from an autosparky.
The regulator monitors the voltage of a battery and decides if it needs a charge or not.
If it doesn't do this, or the charge level coming out of the alternator is to high then battery will be overcharged by the alternator and will try to shed energy by boiling away.
Other than that, yes it will swap directly over. I don't think it was too hard the last one I did.
PostPosted: Sat May 28, 2005 8:46 pm
So a big soldering iron is required Wombat? I was hoping it was plug 'n' play. I've only got a little girly one. Might be time to find a pulsar alternator...
PostPosted: Sun May 29, 2005 10:58 pm
Just checked the good book. I was thinking of replaceing the diodes. The regulator pack (if 16ACR alternator) is plug 'n' play If you need some written destructions give a yell and i'll scan and send them to you.
PostPosted: Mon May 30, 2005 5:47 pm
Ifyou could send me some info Wombat, that'd be great - my manual's packed up somewhere as I'm moving house...
