It is currently Wed Jul 23, 2025 11:13 pm
PostPosted: Sun Jul 15, 2012 7:21 pm
Has anyone here ever switched over a standard steering column for a modern adjustable one mounted in the dash? Something from a late model small car that is pretty compact? It would need some uni joints to work I expect.
I am tall and do the knee knocking thing when I get in..
Alec
PostPosted: Sun Jul 15, 2012 7:58 pm
aparently different models had diff length columns... someone with knowledge will be along soon enough.
I too am tall and have moved my seats rearwards, and lowered my column, though now where I sit the column could be a tad longer...
Perhaps a diff length column would help¿?
PostPosted: Mon Jul 16, 2012 2:42 pm
Ideally, a column which allows the steering wheel to be pointing perpendicular to the floor - i.e. no rake on the dish of the wheel. But, that'll need a uni joint on the column itself I suspect.
PostPosted: Mon Jul 16, 2012 5:19 pm
Does your car have one of those little accessory drop bracket things fitted? If it does then might be worth trying without it first.
PostPosted: Mon Jul 16, 2012 5:29 pm
I've thought of doing this. Make long trips more comfortable.
PostPosted: Mon Jul 16, 2012 7:57 pm
Hey phillb, thanks for the thought but no...... Still the original Leyland column etc in mine complete with rust 8)
Alec
When I was fitting my "different" steering column I could have done it with angle adjust lever too as that is how it was in the Donor car, but I found that altering the wheel angle blocks the speedo and gauges from view which I did not like.
"Let us remove your "SHORTS"
PostPosted: Mon Jul 16, 2012 10:41 pm
Thanks Tony. I saw your build.. it looks good. I am not after power steer though. When you were looking were there many units that would fit or did you have to modify the unit to fit?
Alec
