It is currently Wed Jul 23, 2025 12:44 pm
PostPosted: Sun Jul 15, 2012 7:21 pm
Has anyone here ever switched over a standard steering column for a modern adjustable one mounted in the dash? Something from a late model small car that is pretty compact? It would need some uni joints to work I expect.
I am tall and do the knee knocking thing when I get in..
Alec
PostPosted: Sun Jul 15, 2012 7:58 pm
aparently different models had diff length columns... someone with knowledge will be along soon enough.
I too am tall and have moved my seats rearwards, and lowered my column, though now where I sit the column could be a tad longer...
Perhaps a diff length column would help¿?
PostPosted: Mon Jul 16, 2012 2:42 pm
Ideally, a column which allows the steering wheel to be pointing perpendicular to the floor - i.e. no rake on the dish of the wheel. But, that'll need a uni joint on the column itself I suspect.
PostPosted: Mon Jul 16, 2012 5:19 pm
Does your car have one of those little accessory drop bracket things fitted? If it does then might be worth trying without it first.
PostPosted: Mon Jul 16, 2012 5:29 pm
I've thought of doing this. Make long trips more comfortable.
PostPosted: Mon Jul 16, 2012 7:57 pm
Hey phillb, thanks for the thought but no...... Still the original Leyland column etc in mine complete with rust 8)
Alec
When I was fitting my "different" steering column I could have done it with angle adjust lever too as that is how it was in the Donor car, but I found that altering the wheel angle blocks the speedo and gauges from view which I did not like.
"Let us remove your "SHORTS"
PostPosted: Mon Jul 16, 2012 10:41 pm
Thanks Tony. I saw your build.. it looks good. I am not after power steer though. When you were looking were there many units that would fit or did you have to modify the unit to fit?
Alec
Users browsing this forum: 1071 S and 83 guests
