A better bet would be to replace the worn components.
Clevis pins $15
If that won't improve things, then replace the following as well
Slave pushrod $22
Clutch Plunger $22
Lever Arm $50
Prices here from a single online Australian supplier, shop around as you like.
But for a total of $15 you will probably fix any problems that the spring purports to fix by doing it properly. The rest of the mechanical bits come in at less that $100. For that price you have a brand new set up, good for another 30-40 years instead of a band aid.
michael
66 Mini Minor sponsored by
http://www.lifeonthehedge.com.au/ The Dog Harness Specialists
It was a pleasure ausmini. I'll miss all you misfits and reprobates
