It is currently Wed Aug 20, 2025 11:11 pm
PostPosted: Tue Jul 03, 2012 9:05 pm
Saw this on ebay and it sounded interesting, I haven't got to the clutch on my resto so I'm not familiar with the ins and outs.
http://www.ebay.com.au/itm/MORRIS-MINI-MOKE-LEYLAND-CLUTCH-ENGAGE-GEARS-/140787408695?_trksid=p4340.m263&_trkparms=algo%3DSI%26its%3DI%26itu%3DUCI%26otn%3D18%26pmod%3D221057402611%26ps%3D63%26clkid%3D344504286260544978
PostPosted: Tue Jul 03, 2012 9:13 pm
It's a useful addition to the clutch setup, it's not absolutely needed and is definitely not a standard item but it is slightly helpful IMO.
PostPosted: Tue Jul 03, 2012 9:47 pm
Adjusted properly, it won't need it and a waste of money..
PostPosted: Tue Jul 03, 2012 9:56 pm
Well that's true if you adjust it properly you won't need the spring but it's a lazy way to keep things working well. But that is a bit pricey, I've seen them for $6 on ebay.
PostPosted: Tue Jul 03, 2012 10:01 pm
Waste of time IMO.
I binned the arm return spring, and screwed the arm stop screw in a few turns. I now have a self-adjusting clutch, just like a Rover Mini or 99% of other cars, and all is good.
Particularly as I have a fresh air heater above it and can't get at the stop screw with the grille in. 8)
PostPosted: Wed Jul 04, 2012 5:31 pm
So what does it do ????... Or, rather, what is it supposed to do???
It would seem to pull the release bearing clear of the diaphragm - doing exactly the same job as the standard slave spring (which the blurb claims you still need)???
Cheers, Ian
PostPosted: Wed Jul 04, 2012 7:13 pm
It takes up the slack from the worn clevis pins and other worn out bits. All the worn mechanical bits uphill from the slave spring.
I would rather have things working properly to correct tolerances than cocked up with one of these.
PostPosted: Wed Jul 04, 2012 9:13 pm
A better bet would be to replace the worn components.
Clevis pins $15
If that won't improve things, then replace the following as well
Slave pushrod $22
Clutch Plunger $22
Lever Arm $50
Prices here from a single online Australian supplier, shop around as you like.
But for a total of $15 you will probably fix any problems that the spring purports to fix by doing it properly. The rest of the mechanical bits come in at less that $100. For that price you have a brand new set up, good for another 30-40 years instead of a band aid.
michael
Users browsing this forum: No registered users and 257 guests
